E46 glass roof. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-27-2013, 09:39 PM   #1
Duro1215
My Ride: 99 bmw 328i
E46 glass roof.
would this window be to large for a e46 roof? im thinking about cuting out the window and welding it in.
http://www.andysautosport.com/chrysl...o00900930.html
Duro1215 is offline   Reply With Quote
Old 01-27-2013, 09:43 PM   #2
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Well... That is for a Chrysler 300. So the curvature of the glass will be so far off. So no. It won't work. You'll need a custom panel. I'm not really sure how you're gonna weld glass to the car either.
Old 01-27-2013, 09:50 PM   #3
Duro1215
it comes as part of the roof i will cut the metal around the glass then weld it into the metal on my roof. i was just wondering if it was too long
Old 01-27-2013, 09:56 PM   #4
peytonracer4
:D
My Ride: '00 328i
It doesn't matter if its too long. The curvature is different!!
The 300 has a flat roof. The e46 has a more rounded roof. You will not be able to put that glass on a bmw roof. You will need a custom panel specifically made for your bmw roof. It needs to have the exact same degree of curvature.
Old 01-27-2013, 09:59 PM   #5
Duro1215
why? im sure there would be a way to make it work. i cant find anything for the e46.
Old 01-27-2013, 10:01 PM   #6
Duro1215
and actually both roofs have a slight curve. im sure if you cut 1 -2 inches around the glass you will have enough room to weld the metal in.
Old 01-27-2013, 10:01 PM   #7
diM3tri
My Ride: 330ci + stg2 Scoobie
For the price of doing this correctly you could probably look into forced induction..
350+ HP > glass roof
Current Cars:
'99 Big Turbo B5 A4 (the red one) ^^^
'13 GLI
'91 Ford F150 v8 5spd
Previous Cars:
'05 stg 2 scoobie wagon
'82 VW rabbit vert
'01 330ci
'84 633csi
diM3tri is offline   Reply With Quote
Old 01-27-2013, 10:08 PM   #8
Patton323I
My Ride: R1100GS E46 E53
Just no.
Want a glass roof? Buy an X5.
Patton323I is offline   Reply With Quote
Old 01-27-2013, 10:12 PM   #9
Table3
My Ride: '01 325xi
If you go through with this you have to keep us updated.
Table3 is offline   Reply With Quote
Old 01-27-2013, 10:17 PM   #10
peytonracer4
:D
My Ride: '00 328i
The curves have the be exactly the same. You can't just weld a piece of flat metal to a curved metal piece. I drew this to help you understand. The upper drawing is the top view. The dotted line is the glass. The line with slashes is the potential welds.
The bottom drawing is the side view. The darker line with the slashes is the "new" Chrysler 300 roof. As you can see it lays well under the original roof and may even protrude into the cabin. It DOES NOT line up with the existing roof and roof line making it 100% Impossible to weld it in because the existing roof and new roof do not lie on the same plane.
Old 01-27-2013, 10:20 PM   #11
peytonracer4
:D
My Ride: '00 328i
Here
Old 01-27-2013, 10:22 PM   #12
Vincent_m3
My Ride: 04 M3
Vincent_m3 is offline   Reply With Quote
Old 01-27-2013, 10:24 PM   #13
peytonracer4
:D
My Ride: '00 328i
And no, the 300 roof is way flatter than the e46. What are you judging by, that picture in the ad? Google image a Chrysler 300. It's not even close to the curvature of the e46. Let alone to the exact degree, which is what it needs to be to work.
Old 01-27-2013, 10:25 PM   #14
Bart Taylor
My Ride: 2000 323i touring
do this.
http://www.slidingragtops.com/
Your car, along with every other "stanced" monstrosity, looks like a steaming pile of sh1t.
Originally Posted by mistrzmiasta View Post
i know in your head that sounded like a nice comeback/argument but you just sound like a fool.
Bart Taylor is offline   Reply With Quote
Old 01-27-2013, 10:36 PM   #15
Duro1215
i do like the last idea then id be able to open it. im going to look into the rag top
Old 01-27-2013, 10:42 PM   #16
Duro1215
i like the idea of glass more tho. i wish there was something allready made that would fit the e46 sedan. im probably going to have to get a custom piece of glass made.
Old 01-27-2013, 10:45 PM   #17
Surrept
My Ride: 2002 330ci
This is merely a question as I don't understand 100%. Is it not possible to bend the metal into shape to match the curvature of the e46 roof without affecting the glass housed inside it? I would think that would be possible. It is metal after all.
Surrept is offline   Reply With Quote
Old 01-27-2013, 10:48 PM   #18
Duro1215
that probably would work.
Old 01-27-2013, 10:50 PM   #19
Surrept
My Ride: 2002 330ci
Yeah. I'm not saying it would look perfect. But if you left just enough metal around the edges to bend half of the metal down to match the curvature of the e46 roof, leaving the other half flat to keep the glass from breaking, I would imagine you could make it look "decent".
I can't imagine that being an easy task to accomplish though.
Old 01-27-2013, 10:58 PM   #20
The Thomas J
My Ride: 2002 325Cic
I think this would look really good. If you're going tk do it than do it right & having a custom piece of glass or plexi glass made.
Sent from my SGH-T889 using Bimmer App
The Thomas J is offline   Reply With Quote
hellafag, hellafail
