Old 01-16-2013, 05:41 PM   #21
E RaK
My Ride: 2001 325xit
Happens a bunch with brand new Subaru's at work too.. like previous posters said, I usually go into second and then first.
E RaK is offline   Reply With Quote
Old 01-16-2013, 06:16 PM   #22
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I haven't ever had this issue.
I thought you could access detent pins with trans up...but in any case, it sounds like something in the shifter might be off a bit...and I know there are parts that are not infrequently replaced...look at the 'shifter' diys.
Also, I'd ask if any of you with this issue might have happened to do any mods to your car? Things like the 'clutch stop' or 'cdv delete' anything like that? If so, start by removing the clutch stop.
Not being able to get into first while on the road can be an issue...so I hope none of you reading this think that's common and thus 'okay.' I hope it's something simple...hope it's fluid or a clutch stop...but that's not good.
To be safe, I think you should replace the entire transmission and clutch.
Facebook.com/DMAXstandup
Mangofy your E46!
dmax is online now   Reply With Quote
Old 01-16-2013, 06:23 PM   #23
Stickbuilder
My Ride: Touring, and others
The fix is simple. Swap in an automatic. End of that issue.
[/SIGPIC]I'm fluent in 3 languages:
English
Sarcasm
Profanity
Stickbuilder is offline   Reply With Quote
Old 01-16-2013, 06:26 PM   #24
325inthe510
My Ride: 152ci of madness
Like others have said it's something with how the synchros are aligned.
I too put it in 2nd and then shift smoothly into 1st, I guess that action aligns the synchros properly
325inthe510 is offline   Reply With Quote
Old 01-16-2013, 06:48 PM   #25
Weste46
My Ride: 2001 330ci
I've heard the first gear locking you out could also be from a hydraulic line issue, where the fluid runs around a piston but doesn't leak out, just passes up the system. Also, the slop to the far right of your shifter is supposed to be from the fifth gear lockout pin being made of a different material than where it slides, so eventually it begins to stick and no longer makes it hard to go into 5th.
Sent from my DROID RAZR MAXX
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, AKG 95a FCA, 75d rear subframe, Powerflex 95a RTA, 95a RCA, ECS 88a diff., ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, open-loop EU2 tune, CAI, headers, x-pipe, minus ~180lbs.
Weste46 is offline   Reply With Quote
Old 01-16-2013, 06:48 PM   #26
e46alfonso
My Ride: 330xi MT, mustang gt
I bet many of you are not depressing the clutch pedal all the way to the floor before throwing it in gear. My tranny used to do the same thing when i didn't clutch all the way to the bottom and it was very frustrating not being able to get in gear. If you have a silly aftermarket clutch stop remove it as it reduces pedal travel.
Old 01-16-2013, 07:56 PM   #27
sgoetz628
My Ride: 2002 330 CiC
I had the issue some time ago. It wouldn't go into first or with great difficulty, but only when it was cold - outside and in the tranny. They replaced the clutch at about 45,000 miles. Since I wouldn't imagine they'd have to drain the tranny for this, it's probably old fluid and now, at almost 100,000, it should be replaced, right?
I love my car as much today as the day I bought it
sgoetz628 is offline   Reply With Quote
Old 01-16-2013, 07:59 PM   #28
Weste46
My Ride: 2001 330ci
I don't have a clutch stop. It always happens, always has. I think its a pretty common problem. I absolutely press the clutch in enough.
Old 01-17-2013, 01:37 PM   #29
raymoon
My Ride: Alpinweiß III
I have a VERY MILD clutch stop, and I have the same issue going into first at a stop (However it only happens the FIRST time I depress the clutch. If I depress the clutch, try for 1st, it will almost ALWAYS snag. If I keep the clutch depressed and try again, it normally slides in.
BUT I ALSO have this snagging issue shifting from 1st to 2nd under acceleration. It makes it so I can't shift very fast into second. I have to kind of EASE it in, and wait for it to (possibly synchro?) before it will pop into 2nd. (Going to try replacing with OEM clutch stop and possibly change tranny fluid to redline).
raymoon is offline   Reply With Quote
Old 01-17-2013, 03:44 PM   #30
Elvin123
My Ride: 328i
Originally Posted by stickbuilder View Post
the fix is simple. Swap in an automatic. End of that issue.
lol, NO
Elvin123 is offline   Reply With Quote
Old 01-18-2013, 12:38 PM   #31
raymoon
Switched out the "short-throw" clutch stop, went back to stock. Can honestly say i think it helped about 5-10%. Not much. Still snagging.
Old 01-18-2013, 12:47 PM   #32
MercForHire
My Ride: M235i 6MT
We all have this problem.
Old 01-18-2013, 12:53 PM   #33
My Ride: 2016 Lexus
Originally Posted by Redryan98 View Post
I'm wondering if doing all of the detent bushings/pins in the trans would fix the difficulties going into 1st/2nd gear. I plan on replacing them all when I do my clutch next year using this kit:
http://www.fcpeuro.com/products/bmw-...mw-zfdetentkit
The hard part will be finding/making the tools to get this done.
Nope that's for the shifter returning to center fix.
if its happening often then i would suggest bleeding or getting a clutch job.
Otherwise its normal.
Calling this a "problem" is like saying sometimes your thumb hits the steering wheel when making a turn or sometimes your coat gets jammed between the door when you close the door. its just something that happens. the extremely rare times this happens to me i shift to 2nd then back to 1st or i let the car roll a bit while shifting into first then you *feel* the shifter click in smoothly as the gear teeth/syncros or whatever align indicating this is a rotational/position thing internal to the transmission.
Old 01-18-2013, 01:25 PM   #34
white46
My Ride: e46 323ci
I have the problem too with my current e46 as well as previous e46. I think I had this problem with Acura Integra I had looooong time ago too.
I changed tranny fluid and it helps but the problem persists and I think all manual cars does this.
white46 is offline   Reply With Quote
Old 01-18-2013, 01:57 PM   #35
lcoleman
My Ride: '79 Massey Ferguson
1. Double clutch.
2. Fresh fluid.
3. Use fluid that works well in cold weather (Redline D4).
Old 01-18-2013, 02:08 PM   #36
MercForHire
My Ride: M235i 6MT
double clutch always works for me
i am a double clutch fan
Old 01-18-2013, 02:35 PM   #37
Hoebama
My Ride: e46
Simple Driver effort to tranny equation...
M3: Stick > Auto
All NA NON-M3: Auto > Stick
<200 HP cars: Auto > Stick
Supercars: Paddle
<150HP: Take the bus
Hoebama is offline   Reply With Quote
Old 01-18-2013, 03:08 PM   #38
TerraPhantm
My Ride: M3 & ZHP
M3: Stick > Auto
Supercars: Paddle
I'd personally prefer a manual in a less powerful car than a more powerful one...
Old 01-18-2013, 03:28 PM   #39
My Ride: 2016 Lexus
yep. that's why the new M5 is in DCT form. yet they still made stick for the fanboys. apparently stick in a very powerflu car just makes things awkward and somewhat sloppy (not to mention downright slower)
of course we're talking about modern dual clutch transmissions and not traditional slushboxes
Old 01-18-2013, 03:44 PM   #40
evo7
My Ride: 330i
last time i inquired about this, i was told it could be the clutch master cylinder leaking internally.
evo7 is offline   Reply With Quote
