Old 01-15-2013, 11:36 PM   #1
eclipsor
My Ride: stahlblau
Send a message via AIM to eclipsor
car issues this morning
ok guys im really sorry for posting a thread. i tried searching but i found too many diff answers and none were specific to my exact symptoms.
anyways
so this morning i started up my car and it started idling rough. i decided to test it out real quick, so i put the car in reverse and it was backing up in bursts. then i put it in drive and drove for a few yards and then the engine died and the check engine light and the battery light came on. i started the car again, and pretty much the same thing happened. during this, my car barely had any power, when i slammed the pedal, barely anything happened.
anyways i go to work, come back to try to figure out whats going on. i turn on the car and it feels fine, go for a drive and the car feels normal again.
i scanned for codes and this is what i got
p0313
p0174
p0128
p1350
p1343
recent work done that might be relevant:
new spark plugs and a few new coils about 6 months ago
replaced the lower intake boot that was causing a vacuum leak also about 6 months ago
Jet Black 1994 325is -> Steelblue 2003 325i
eclipsor is offline   Reply With Quote
Old 01-16-2013, 06:10 AM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Suggest you read the first 2 links below in my signature for all but 1 code.
Likely you have a vacuum leak causing misfire?
How cold was it when this problem happened?
Pay special attention to the SAP vacuum hose along the valve cover, DISA, CCV hoses, really check the bottom hose closely.
Note, when you have misfires like this, usually you can turn the engine off and restart and they may clear so you can drive for the time being.
The P0128 it a thermostat/cooling system code, suggest you read this link - http://forum.e46fanatics.com/showthr...491&highlight=
Old 01-18-2013, 11:56 AM   #3
My Ride: Lexus
After reviewing your codes and other info, I would replace the entire CCV and fuel filter. Let me know if you need me to stop by and visually inspect your car.
Old 01-19-2013, 03:04 PM   #4
eclipsor
My Ride: stahlblau
Yeah the car has been driving fine again, but idk for how long. Do you guys think my fuel pump should be changed? I thought it was weird how some of the codes said low fuel detected when I had a 100% full tank of gas -_-
and i dont think it was that cold, maybe like 50-60 degrees
how much should i expect to spend on replacing the ccv and fuel filter though? I heard the CCV isnt really DIY-able. Especially not by me
Old 01-24-2013, 09:19 PM   #5
eclipsor
My Ride: stahlblau
anyone?
Old 01-24-2013, 09:27 PM   #6
325xiSLEEPER
My Ride: BMW 325xi
the ccv is absolutely diy-able and the parts are about 169.00 from bav auto.
325xiSLEEPER is offline   Reply With Quote
Old 01-24-2013, 09:32 PM   #7
jfoj
I would hold off on the fuel pump and worry about the thermostat and the lean codes.
Check intake boots, DISA Oring and figure out if the CCV lower oil return line has broken.
You likely need the engine CCV, but you may be able to buy yourself some time so you can shop it around or find time to DIY.
Old 01-24-2013, 10:05 PM   #8
eclipsor
My Ride: stahlblau
Also, my engine has been burning through oil pretty quickly. The yellow light comes on about every 2 weeks after I top it off with a quart. There are no signs of a leak though (using the most common leaks thread). cant that also be a symptom of a bad ccv?
Old 01-24-2013, 10:13 PM   #9
325xiSLEEPER
My Ride: BMW 325xi
when was the last time you had the vcg done can it be leaking. and the ccv could cause that but it seems quick you sure theres no leaks that you can see?
Old 01-24-2013, 10:14 PM   #10
eclipsor
My Ride: stahlblau
also anyone have a link to the ccv kit i would need on like bma parts or something? im having trouble findiing and dont really know what exactly i would need to do the ccv
Old 01-24-2013, 10:15 PM   #11
eclipsor
My Ride: stahlblau
if the vcg is leaking, wouldnt you be able to see it leaking on the left side of the engine bay on the metal plate? there's nothing there.
idk when it was changed, i bought the car used. but when my friend was replacing my plugs and whatnot a few months ago, he said the vcg was fine
Old 01-24-2013, 10:24 PM   #12
325xiSLEEPER
My Ride: BMW 325xi
http://www.oembimmerparts.com/produc...1703484e36.htm heres an e36 ccv pretty cheap. i only asked about vcg because i had a tiny leak which cause lean misfire codes.
Old 01-24-2013, 10:33 PM   #13
eclipsor
My Ride: stahlblau
the e36 one fits? and is that the only actual part i would have to replace? i thought there was a kit that comes with hoses and stuff
Old 01-24-2013, 10:40 PM   #14
325xiSLEEPER
My Ride: BMW 325xi
my bad i thought u had the 94 325is its a 2003 325i right?
Old 01-24-2013, 10:41 PM   #15
eclipsor
My Ride: stahlblau
yes sir, i wish i still had an e36 lol
Old 01-24-2013, 10:47 PM   #16
325xiSLEEPER
My Ride: BMW 325xi
ok well theres two options the oem ccv kit or the cold climate version seeing how you in socal the oem one will do.
heres the link to both you can decide..
http://www.oembimmerparts.com/produc...itoeme46cc.htm COLD CLIMATE VERSION
http://www.oembimmerparts.com/produc...skitoeme46.htm OEM HOSE KIT AND CCV
http://www.oembimmerparts.com/produc...7501566e46.htm
no real difference the cold climate is insulated....
Old 01-24-2013, 10:52 PM   #17
jfoj
This is likely what you are looking for??
http://www.ecstuning.com/BMW-E46-325...ions/ES260025/
Double check the application as it is not 100% clear what year and model car you have, assume it is a 2003 325i??
What you also need to do is get the dipstick removed and clean out the double wall of the dipstick tube if your is a double walled unit and also verify your engine coolant temperature is correct, as you mention you are using a lot of oil as well.
See this links here -
http://forum.e46fanatics.com/showthr...ghlight=report
http://forum.e46fanatics.com/showthr...light=dipstick
Old 01-24-2013, 10:53 PM   #18
325xiSLEEPER
My Ride: BMW 325xi
thats aftermarket one cheaper if u wanna go that way
