Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 10-29-2013, 10:05 AM   #1
Bruno1
My Ride: 2005 bmw 325i
Intermittant HID headlight
the left hid headlight on my 2005 324i sometimes flickers, sometimes it shuts off. Then, when I manually turn it off on, it comes on again. Sometimes the headlight fault indicator comes on with it. Is this a bad igniter or control unit?
Bruno1 is offline   Reply With Quote
Old 10-29-2013, 10:32 AM   #2
mr_party21
My Ride: 2003 330i
Re: Intermittant HID headlight
I had the same problem with a car i used to have, it turned out that the bulb went out. Easiest way to check is to remove the bulb and if rhe center looks cloudy or burnt. Then its time to replace your bulb
mr_party21 is offline   Reply With Quote
Old 12-10-2013, 04:26 PM   #3
Bruno1
Although I did not see anything wrong with the bulb and after a lot more testing (like swapping the control unit from left to right) I eventually replaced the bulb and that fixed it. Thanks for the tip.
Display Modes
