///M3 Forum
Old 01-16-2013, 07:30 PM   #1
fatskidmark
My Ride: E46 M3
Car won't start sometimes?
When I go to start my car, I'll turn the key and it'll just crank over without firing, then I just turn the key back off and turn it back to the start position and it fires right up? Anyone had this issue before? It only does it sometimes, completely random...
fatskidmark is offline   Reply With Quote
Old 01-16-2013, 08:12 PM   #2
nojoda
My Ride: 06 M3Vert 6MT JB/CIN
is your car manual or smg? this happens to me, but its either me not putting in the clutch right, or if the floor is slanted. Ive noticed turning the car on first it never happens but in neutral it does
2006 BMW M3 VERT 6MT S/C VF570 (CURRENT)
2007 B7 AUDI A4 2.0T CVT FWD (BRILLIANT BLACK) TRADED
2002 E46 BMW M3 SMG II (TIAG) RIP
INSTAGRAM : @itsjorgebrah
nojoda is offline   Reply With Quote
Old 01-16-2013, 11:53 PM   #3
Khiladi1020
My Ride: E46 M3 (sold)
This exact issue just started happening with me in the past week. Manual trans. Sounds like its about to start, but doesn't. Start over and it fires right up. Not sure yet but suspects are battery, alternator, maybe dirty maf sensor...?
-Nick
'02 M3 6MT
Khiladi1020 is offline   Reply With Quote
Old 01-16-2013, 11:54 PM   #4
$ilent ///M
My Ride: 03.5 M3 smg lsb
I would look into seeing if it holds pressure in the fuel rail you can hook up a pressure gage on the shrader valve by the fuel filter on the regulater. or maybe the crank position sensor going bad. Have you checked to see if you have any codes stored.
$ilent ///M is offline   Reply With Quote
Old 01-17-2013, 12:25 AM   #5
fatskidmark
My Ride: E46 M3
My car is a man. No codes besides the belt ten. I don't see it being the battery, alt or maf, none of these items would cause this issue I don't think. The fuel pump is a suspect though, good call. I'll find a way to check this, although it may be hard because it only does this once in a while...
Old 01-17-2013, 12:26 AM   #6
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
Ive had a clutch switch go bad so dont count that out. No click nothing.
maybe bypass it and see. Same thing some days work some not. One day just stopped starting.
Luckily it wasnt the starter.
"Player-haters turning bitch like they have vaginas ‘Cause we see them dollar signs and let the cash blind us.
Money'll brainwash you and leave your ass mindless..When snakes slither in the grass spineless.."
MachRc is offline   Reply With Quote
Old 01-17-2013, 12:30 AM   #7
fatskidmark
My Ride: E46 M3
^^Yes, this is a great idea! I can't remeber what it's called, but there's a washer thing on the top of the clutch pedal and mine's worn out. I bet that's the problem, damn, forgot all about that sh!t. I'll try to fix this asap and update you guys for anyone else who has this problem...
Old 01-17-2013, 12:31 AM   #8
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
your ignition switch could be going bad
/_________\
O==[][]==O
Old 01-17-2013, 12:32 AM   #9
fatskidmark
My Ride: E46 M3
^^Sick wagon bro!
Old 01-17-2013, 12:34 AM   #10
330i ZHP
330i ZHP's Avatar
thank you
/_________\
O==[][]==O
Old 01-21-2013, 06:57 PM   #11
joelnet
My Ride: '02 M3
my car does this. manual. it's annoying. let me know if you find the solution.
2002 e46 M3 - Jasper Motor Werks Stage 3 kit (JMW Re-flash, JMW Headers, JMW X-Pipe), H&R Springs
joelnet is offline   Reply With Quote
Old 02-05-2013, 02:11 PM   #12
2002topasblueM3
My Ride: 2002 M3
It could be a loose terminal on your battery or if you've installed extra wiring harnesses in your engine bay for lighting or something, you could have a loose ground wire or terminal screw on the black box in the top left compartment near the reset button. This may not help at all but just suggestions. A friend of mine owns an Indy shop and said that a kid tried to install angel eyes himself and his car would randomly not start and would click several times before final turning over. He brought it to my friend's garage and he tightened the bolt where the kid had attached the ground wire and he never had that problem again. Apparently the kid just left the bolt way too loose
2002topasblueM3 is offline   Reply With Quote
Old 02-05-2013, 02:15 PM   #13
fatskidmark
My Ride: E46 M3
Haven't wired anything in...
Old 02-05-2013, 02:50 PM   #14
Ballerbrian4u
My Ride: 2004 BMW m3
This thread came at the best time! This happened to me for the first time last night. I have a smg.
Ballerbrian4u is offline   Reply With Quote
Old 02-09-2013, 12:20 PM   #15
Ntrb8s4
My Ride: X5 / B8 S4
Happens to my SMG. Normally when the cars been sitting for a few days.
Ntrb8s4 is offline   Reply With Quote
failure, issue, maintenace, won't start
