Old 02-01-2013, 03:06 PM   #1
diM3tri
My Ride: 330ci + stg2 Scoobie
Car won't start..
I got in my car and when I turn the key absolutely nothing happens.. The accessories won't light up, the car won't click. Nothing happens. I had it in the shop a few days ago for a coolant flush and haven't driven the car for 3 days but the battery was fully charged and driving perfectly 3 days ago. My battery is less then 2 years old..
Current Cars:
'99 Big Turbo B5 A4 (the red one) ^^^
'13 GLI
'91 Ford F150 v8 5spd
Previous Cars:
'05 stg 2 scoobie wagon
'82 VW rabbit vert
'01 330ci
'84 633csi
diM3tri is offline   Reply With Quote
Old 02-01-2013, 03:20 PM   #2
rudycoop
My Ride: 3 pedal 330i
did u try a jump? Do u have a voltage meter? Something could have drained it. A failing final stage resistor perhaps?
rudycoop is offline   Reply With Quote
Old 02-01-2013, 03:21 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Start by wiggling the connections on battery, check under +terminal under hood for looseness or corrosion. Use multimeter to check battery rather than assume it's good because you want it to be.
FSR causes issues draining the battery overnight...maybe if you left your lights on, but those should turn off automatically I think.
Anyway, hth
Facebook.com/DMAXstandup
Mangofy your E46!
Old 02-01-2013, 04:26 PM   #4
diM3tri
Anyway, hth
I wiggled the connections a bit and sure enough it was the negative to ground battery connection in the trunk that ended up being the problem. As soon as I wiggled it and tried starting it, it started right up. I assume I have a loose connection somewhere in that black wire.. Thanks for your help
Current Cars:
'13 GLI
Previous Cars:
'82 VW rabbit vert
'01 330ci
'84 633csi
