Old 01-18-2013, 03:10 AM   #21
MJLavelle
My Ride: 2001 BMW 330ci
Originally Posted by My325XI View Post
I bought a $25 code reader off Amazon. Works great and its for any OBD II vehicle.
There are codes that are proprietary to BMW's only, and a regular OBDII II scanner will not read them, or it will give you the wrong code.
That would be why there are scanners made specifically for BMW's. You can reset an SES light, but for certain codes, this will not give you the correct information.
Old 01-18-2013, 03:13 AM   #22
MJLavelle
Originally Posted by brokensmile209 View Post
can you tell me more about this Peake R5/FCX 3 scanner? is this the best plug in play tool to clear my problem?
This scanner will work, and it will let you reset your SES light. But the codes it gives have to be matched to their tables, and are not the actual BMW code numbers. This makes it a bit more confusing to use, but it will work.
Old 01-18-2013, 07:43 AM   #23
miweber929
My Ride: 02 330xi
Originally Posted by trj View Post
Are you speaking for the whole community, advising against BMW scanner? It looks like only the people receiving broken items are posting on the threads, whoever receives a working item, they dont post. Only issue is, the one coming from overseas will take more time and more delay if you have to send one back. I believe xcar360 who are the ones coming with this product for cheap is a sponsor on this site now. So, one can directly deal with them.
No offense, but dont bash on a product because someone else couldnt get it to work or got a bad product. Or, did you get a bad one too? They are replicas of the BMW scanner 1.4 from PAsoft, which cost $650. You cant expect to have same level of quality and customer support from the cheaper(super cheap) version.
I am not asking OP to reset the code at auto zone, at least read the code to see what caused it.
I was giving OP a choice since everyone else seemed to give their choices. I bought BMW scanner 1.4 from a US seller paying more than $32($48 to be exact) because I needed it immediately to code my retrofitted xenons. However, the chance of people receiving the broken item from China or Taiwan is same as getting one from US seller. It is the same product with higher mark up price because it is being sold from a seller in the US. I have compared the one from US seller(mine) and the one ordered recently through xcar360(another forum member here). Both are same, even the sticker is attached in the same position(covering the indicator lights).
DIS, INPA, carsoft, etc available over ebay are also cheaper pirated versions. They use vag-com cables modified to work with the stated programs.The Vag-com cables you see for $10 are also the replicas from China, and you have the same chance of getting a bad one.
Plus you can do a lot of damage to the car if you dont know how to use them. I have all those softwares and prefer BMW scanner to read and code simple things on my car. If I have to do something that BMW scanner can't do, then only I resort to INPA.
That is the reason I advised OP on getting a BMW scanner.
Your original post indicated a $32 scanner, clearly the Xcar one and that was what I was referring to, so take it as you will but the last batch HAS been documented flakey, and all Xcar is willing to do (after much back and forth) is look at it after shipping it back to Hong Kong. So I waited a month to get it, spent 2 weeks screwing around with 3 different laptops, emailing Xcar back and forth and will have a month to get it back to him and another month before I see it; cost to ship it was around $25 according to my mailroon at work. So you know, it's a big waste if money and time at this point. I suggested to Xcar he simply replace the bad ones as they obviously have an issue and are quite cheap to make with no response. You may want to read what was quoted and what was written before jumping to conclusions. Lots of satisfied owners post up as well, which is why I ordered one.
The PAsoft software I imagine is great (never got to use mine), and the reader is great as well, but the OP has zero desire to actually read the code and only asked about resetting the light so any $30 Autozone reader will do that and be 80% easier for this guy to use. I know, I have one. And bing! it reads as a bonus. And works right out the box or Autozone will exchange it.
If the OP wanted to PROGRAM his car, I'd suggest getting a scanner, FYI, but like I mentioned spend the money on one from these shores to save headaches. Sponsor or not the Xcar parts and service are pretty suspect from my experience.
So yeah, I'm speaking for the community in general I guess.
miweber929 is offline   Reply With Quote
Old 01-18-2013, 09:12 AM   #24
trj
My Ride: 325Ci
Sorry it didn't work for you. I guessed it right then. You were one of the people who got a bad one.
My point was if he needs to buy one that's an option. Also a scanner will do nothing for his car unless he fixes what caused the light in the first place. Also you got a bad one doesn't mean he will get a bad one. I got a good one, so I still am in support of BMW scanner 1.4. You should also note that I bought it from a US seller not xcar360 for prompt shipping although the product is the same.
Old 01-18-2013, 10:58 AM   #25
bimmernut3
My Ride: '05 330cic, '01 540i
Boy, a lot of information being posted on the scanner. It would nice if one of you guys could post showing ALL the scanners, with pros & cons and showing the approx. cost for each & what it will or will not do, all on one post. Sure would make it easier for me to evaluate. BTW, thanks to all the posters on this subject. It's really good info.
'05 330ci
[IMG][/IMG]
bimmernut3 is offline   Reply With Quote
Old 01-18-2013, 11:45 AM   #26
trj
My Ride: 325Ci
I use all three; BMW scanner 1.4, INPA, generic OBD II scanner. But my favorite is BMW scanner 1.4 for general usage.
BMW scanner 1.4
Pros:
Cheap($32 if you buy it from China)
Easy interface, Less chance of messing up.
Read and translate BMW specific codes.
Codes that the generic OBD reader cant read can be read.
Reset the codes.
Airbag light reset.
Live data.
Coding of DMS, EWS, LKM, whatever module you can think of. eg: Xenon flash from halogen lights, DRL disable, euro hazards, one touch window operation, door lock at particular speed, automatic lock disable, alarm coding, many more..... you get the idea.
Can read every little module present in your car separately. Eg: ABS, heated mirror, NAV, heated seats, etc.....
Cons:
Chinese made hence, not original(original is $650)
If you buy from china, takes a long time to ship. Hence I bought it off a US seller(paying more than $32 to xcar360).
No customer support or manual.
Hassle if you have to return it back.
Need a 20-pin adapter to work with Pre2000 cars.
A bit confusing to set up on a 64-bit operating system.
INPA:
pros:
can do everything stated above and more. Like changing the DME software, Transmission software.
Very powerful
Cheap(can be had for around $35 with the softwares and cable, and just modified vag-com cable only can be had for $10)
A little more instructions available over the internet forums on how to use it.
cons:
command based, hence not intuitive at all.
Setting up a computer with this would make one go crazy if they dont know what they are doing.
You can do a lot of damage if you dont know what you are doing.
Generic OBD tool:
pro:
works on all OBDII cars.
Check engine light reading and clearing.
Available in any auto parts store. (costs around $15 to whatever you can imagine)
Cons:
Not BMW specific codes.
Doesnt read anything else but the SES light.
Costs almost as much as BMW scanner.
If you plan to change settings and read BMW specific codes for your car without the risk of messing up, BMW scanner is the best bet.
Else you can get generic OBDII readers.
If you are more adventurous, get INPA.
All three costs almost the same, but INPA and BMW scanner are immensely powerful than generic OBDII scanner.
As with all other parts, there is a chance you get a non functioning module. Doesnt mean its useless. Of course, over the course of time I have received numerous items that were not working, but I dont ask people not to buy it because I received a non functioning one. Your choice, you get what you pay for and decide how much time you are going to spend to use/learn it.
With INPA, its cheap and very powerful but you will need a lot of time to set it up, and learn how to use it.
With Generic OBDII, its just plug and play.
BMW scanner is right in the middle of those two.
Your choice.
Also OP, get your codes scanned. Just resetting the code wont do squat. Find why the light was triggered.
Old 01-18-2013, 11:50 AM   #27
bimmernut3
BMW scanner 1.3=4
Pros:
Reset the codes.
Airbag light reset.
Live data.
Cons:
INPA:
pros:
Very powerful
cons:
Generic OBD tool:
pro:
Cons:
Your choice.
Thanks trj, this is good. What's the issue with the 1.3.4 set up in windows7
'05 330ci
[IMG][/IMG]
Old 01-18-2013, 12:08 PM   #28
trj
My Ride: 325Ci
Sorry, it was a typo as I wrote 1.3=4. It is BMW scanner 1.4
The generic drivers provided with it are not compatible with any variation of 64 bit windows. If you have 32 bit windows then its not an issue at all.
However, there is a big thread on BMW scanner 1.4. You might want to check that thread out, there are people who have set it up with windows 7 64-bit and provided the steps. I run it on mac book pro with win xp on parallels. I do not have the specifics on how to install it on 64 bit machine, but in that thread its mentioned.
Old 01-18-2013, 06:18 PM   #29
brokensmile209
My Ride: 2001 BMW 325ci
BMW scanner 1.4
Pros:
Reset the codes.
Airbag light reset.
Live data.
Cons:
INPA:
pros:
Very powerful
cons:
Generic OBD tool:
pro:
Cons:
Your choice.
thank you, i just place a order on the bmw scanner 1.4 from amazon, it from a seller in united states not china, hopefully this will help read code and help me clear it.
http://www.amazon.com/gp/product/B00...&pf_rd_i=typ01
brokensmile209 is online now   Reply With Quote
Old 01-19-2013, 05:17 PM   #30
trj
My Ride: 325Ci
Nice. You found a good priced one. Cheers.
Old 01-19-2013, 05:41 PM   #31
jfoj
My Ride: '06 330CiC, '03 M5
Launch CReader VI is my first go to tool for any ODB car. I have a bunch of tools, some stand along and some computer based. I even have a Peake Reader but do not use this often because it cannot display real time data.
If you shop the CReader VI a bit, you might be able to get for under $100 off shore.
I think I scored mine on ebay for $84 as I recall.
Color display, on tool graphing, on tool recording, real time data, fast & simple.
As far as the graphing and recording, it is a bit limited, but no other handheld in this price range gives you this many features that I am aware of?
+1 for the Launch CReader VI, I keep this one handy and use it first before I drag out my other tools.
If I had less than $150 on scan tools for a BMW, I would buy a Launch CReader VI and a the BMW Scanner 1.4.0, far superior and cheaper than the Peake, you can do coding, airbag reset and read BMW specific codes with the BMW Scanner 1.4.0 and the CReader does not require you to dig out your computer for the first crack at your issues.
Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619
Lower hose fan switch O-ring - BMW #13621743299
Old 01-19-2013, 05:45 PM   #32
jfoj
That is a decent price, just beware it is not "fulfilled" by Amazon, so it likely will could from Asia, but who knows for sure??
This recently happened to catch someone with a ELM327 interface for use with a Driod phone. They went with the cheaper item on Amazon and did not pay attention to the fact it was not "fulfilled" by Amazon.
Update on how long it takes to show up.
Old 01-19-2013, 05:56 PM   #33
trj
My Ride: 325Ci
+1 on shipping time update.
Would be a nice, if indeed you get it quick and from US no one have to put up with crap from xcar360.
Old 01-19-2013, 07:32 PM   #34
brokensmile209
Found a Launch Creader VI for $62 brand new, also there a used one on ebay bidding for $29.99, still debut on which one I should pick
Sent from my SGH-T999 using Bimmer App
Old 01-19-2013, 08:05 PM   #35
jfoj
Make sure it is a CReader VI and not the CReader V!
Where did you find it for $62, this is a deal for this tool!
Old 01-19-2013, 08:11 PM   #36
jfoj
I found the $62 one, the ebay one is already at $40 and it has over 4 days of time on the auction, it will likely go for over $100??
The $62 one is from Asia, but it is worth it.
Hopefully the seller is legit and will get the unit shipped quickly, but most of the take 12-16 days from Asia?
Get the Launch and this - http://www.amazon.com/Patuoxun-V1-4-...mw+scanner+1.4
For under $100 you have the best set up for the price.
Old 01-19-2013, 08:24 PM   #37
brokensmile209
Jan 25 to 29 delivery arrived date
Old 01-19-2013, 08:27 PM   #38
brokensmile209
Estimated delivery jan 25 to jan 29
Old 01-19-2013, 08:56 PM   #39
brokensmile209
Yes it the Creader VI for $62 maybe from Asia, pretty good deal
Old 01-19-2013, 09:01 PM   #40
brokensmile209
Yes the $62 maybe from aisa but it a good deal
