which bmw scanner can help sloved my problem? - Page 4 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-30-2013, 01:11 PM   #61
brokensmile209
My Ride: 2001 BMW 325ci
Hey everyone I finall got my Creader VI from china today, I received the good in 9 day, I paid $58 plus free shipping, what a steal, wow the Creader VI is big , also got my bmw scanner 1.4 for cheap at Amazon for $26.
Sent from my SGH-T999 using Bimmer App
brokensmile209 is offline   Reply With Quote
Old 01-31-2013, 05:06 PM   #62
Zardoz33
My Ride: 2001 325xi
Sweeeeeet. Please let us know how it performs.
Zardoz33 is offline   Reply With Quote
Old 01-31-2013, 05:15 PM   #63
mikeetastic
My Ride: lots of 3
sorry for the noob question, but why the 2 scanner?? do you have a link from amazon where you got that BMW 1.4 scanner?
TIA..
mikeetastic is offline   Reply With Quote
Old 01-31-2013, 06:25 PM   #64
jfoj
My Ride: 330CiC, M5, X5, E93
Man, Amazon pricing is all over the mat at times. The BMW Scanner 1.4.0 that was under $30 last time I checked is now over $75!
As for why 2 scanners.
You need real times data and BMW Scanner does not always give that to you, in addition BMW Scanner cannot log or graph, the CReaderVI can graph on the tool, maybe not the greatest, but does graph.
Also you can keep the CReader in the car, not computer needed, and when you get a CEL come on, you can pop it in, check and clear the code as needed when your laptop is still at home.
Also the CReader has a pretty good code look up built into it and it works on all OBD cars, not just certain year BMW's.
For the money they spend on these 2 tools, less than $100, blows the Peake Reader out of the water as the BMW Scanner can also code modules and read and clear airbag faults as well.
Old 01-31-2013, 10:38 PM   #65
brokensmile209
i haven't got the time to test the bmw scanner yet because i haven't install the software yet because my laptop is running window 7 64bit, the Creader VI is easy to used, just plug and play and i also updated the Creader VI to the lasted software online
Old 01-31-2013, 10:48 PM   #66
brokensmile209
TIA..
sorry, i check up on amazon again and the bmw scanner for $26 is gone, look like i brought the last one from seller Patuoxun, the reason why i brought two scanner is because if i were to brought a Creader VI for $100 from a usa seller, i would rather order one from china for $58 and spend the extra $50 left to buy a bmw scanner. So i brought bmw scanner and Creader VI for total $84, i kill two bird with one stone and save a ton , you can try the link below for a bmw scanner 1.4
http://www.xcar360.com/bmw-scanner-1...scan-tool.html
or contact the user (MRHEAT) in this forum, he has one bmw scanner for sale for $34 and he is in the US.
Old 01-31-2013, 10:54 PM   #67
mikeetastic
My Ride: lots of 3
do i still need the round 16pin adaptor if i buy Creader VI for my 99 323i?
Old 01-31-2013, 11:59 PM   #68
brokensmile209
Im not sure what adaptor the 99 323i used, you might wanna ask around this forum
Old 02-01-2013, 05:17 AM   #69
jfoj
If you have the 16 pin under the dash, I believe you will be fine without the adapter, however, you need to have the round cover for the 20 pin port and it has to be installed as there is a jumper that enables the 16 pin port.
The adapter cables are needed of you plan on using something like BMW Scanner 1.4.0.
The cables are only like $15 so when it doubt it is better to have one on hand.
Old 02-01-2013, 08:27 AM   #70
markgbe
My Ride: 2002 BMW 330ci
Originally Posted by bimmernut3 View Post
For a simple SES light, I went the 'cheap' way, I bought a blue tooth 'dongle' off ebay for about $12 & down loaded torque lite app for my droid. pair the two, pull code(s), clear code(s) goggle code. Works on my '01 540i, '05 330cic, '96 Z71 truck & wifes '04 Trailblazer. Very simple & cheap. Can also read several items on the car like O2 voltage, coolant temp, RPM's, Speed......
You can go cheap or exspensive, pick your choice.
so this just gives you the basic OBD2 codes like a cheapo autozone scanner will, right? Have you found that it does anything useful that a cheapo OBD2 scanner wont?
markgbe is offline   Reply With Quote
Old 02-01-2013, 02:04 PM   #71
jetson22
My Ride: 325CI 330CI 328IS
Does anyone know if the BMW scanner 1.4 will work with windows 8?
jetson22 is offline   Reply With Quote
Old 02-01-2013, 02:47 PM   #72
jfoj
Torque or actually Torque Pro for $5 is anything but a cheapo Autozone scanner.
1. Torque will display real time data, such as MAF reading, coolant sensor, throttle position, etc.
2. Torque can graph sensor data.
3. Torque can read codes, clear codes display Emission Readiness Codes.
4. Torque can display trip info and actually overlay your route on a map and show your speed over different sections of your route.
5. Torque may be able to graph 1/4 mile times using vehicle speed sensor and GPS on your Droid device
I guess there may be a lot more things that Torque can do, however, I have not spent a lot of time working with it.
For $20 it really is a no brainer in my opinion and it will do far more than most scan tools costing 5-10 times as much.
Old 02-01-2013, 03:00 PM   #73
morningisbad
My Ride: E46 M3 Vert
How do you get out to plot speed on a map?
"When makin' a questionable decision, sometimes the only way to find the answer is to shut your eyes & mash the pedal to the metal, you guys."
-Karl Welzein
morningisbad is offline   Reply With Quote
Old 02-01-2013, 03:01 PM   #74
morningisbad
Yes. Search the scanner 1.4 thread and you'll get detailed instructions
-Karl Welzein
