Old 01-18-2013, 11:08 AM   #21
mattfarrington
My Ride: 04 325xi
Originally Posted by Think0rz View Post
max psi kit throws 0 codes, has no CEL's and does pass inspection as previously stated by max psi. It's the only turbo kit available that is emissions proof for the e46
Exactly. And if the cats were to be removed, all I would need to do is follow teh DIY guide on these forums for some programable O2 sensors, and program them for the values as shown, and I should be fine.
Or have a shop do it, but I don't plan on removing cats.
mattfarrington is offline   Reply With Quote
Old 01-18-2013, 03:33 PM   #22
forcefedvw
My Ride: 03' Z4 '00 VW
You just have your readiness set to ready then all tests pass
Innovative Performance
http://www.facebook.com/pages/Innova...609652?sk=info
2JZ-GTE Conversions & GM LS-Engine Conversions
forcefedvw is offline   Reply With Quote
Old 01-18-2013, 05:46 PM   #23
Forcefed M3
My Ride: HPF Stage 2.75
Turbo + cats = melted mess!
Forcefed M3 is offline   Reply With Quote
Old 01-18-2013, 05:48 PM   #24
mattfarrington
My Ride: 04 325xi
BMW 135i.. 335i.. Those are turbo cars with cats.
Old 01-18-2013, 08:43 PM   #25
mike@maximumpsi
My Ride: 02M3T
There are tons of properly tuned turbo cars running cats.
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 01-18-2013, 11:00 PM   #26
aahmed2016
My Ride: 2003 330i ZSP/CP/PP
All I can tell you is that either go for the Max PSI ksit, or you might have to drop a bit more money into the emission testing. If you know what I mean.
Originally Posted by MercForHire View Post
Spends $2000 on car DVD + stereo -> Running 25000 mile oil changes and 87 gas with blown shocks
aahmed2016 is offline   Reply With Quote
Old 01-18-2013, 11:05 PM   #27
mattfarrington
My Ride: 04 325xi
I'll spring for the kit. lol
I can't afford to buy another M3, same exact year, model, type, color, etc.
In NH if you've got the SAME EXACT car, use the registration from the clean car, have them test the clean car... but write the sticker for the boosted one, you'll pass. (illegally).
Old 01-19-2013, 01:37 AM   #28
Forcefed M3
Lol ok. There are factory designed turbo cars running cats yes. Lets see how these cars cats hold up, because every other F/I company on this forum products has roasted cats. These properly tuned cars are not making the same power either.
Old 01-19-2013, 01:39 AM   #29
Forcefed M3
Designed with lower boost pressure and smaller turbos.
Old 01-19-2013, 03:06 AM   #30
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
I personally wouldn't run a big turbo car with cats but I thought I recall Jim Pac's car (Og HPF #001!) having cats in it.
Old 01-19-2013, 04:02 AM   #31
E85head
My Ride: E46 M3
Where does the HPF downpipe meet up with the factory exhaust? Is it to the section after the headers or rear section? European cars have the stock cats in the section right after the headers..
E85head is offline   Reply With Quote
Old 01-19-2013, 04:58 AM   #32
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
HPF setup replaces the factory section 1 with a straight 3inch pipe along with the wastage dump tube and then splits into a duel pipe connecting to the factory section 2 which in turn is connected to the stock muffler configuration.
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 01-19-2013, 05:08 AM   #33
being3
Modded ///Member
being3's Avatar
Here's a photo I found on the forum that shows the HPF exhaust setup. If u look at the connection from section 1 to 2 the Y could be cut out and put a cat in that section. There are several slim stainless cats that could be squeezed in to the stock section 2. The setup pictured has an aftermarket single pipe for section 2 so a 3 inch cat could be dropped in. The only issues is that far back the cats may be rendered ineffective as the heat may not be as high that far back to burn efficiently. I know that Proefi has a module that mimics sensors so u don't throw any lights. It may only work with their system not sure. Click image for larger version
Old 01-19-2013, 07:44 AM   #34
Commanderwiggin
My Ride: 1000rwhp Turbo M3
I believe you are correct good sir...and Jim's car ran without issue!
Old 01-19-2013, 08:55 AM   #35
mattfarrington
My Ride: 04 325xi
Well, I'll msot likely run without cats when I get the kit. Easy way to pass in the programmable O2 sensor.
http://forum.e46fanatics.com/showthr...aders+no+light
I do love the smell of a car running catless. That's one sexy smell.
But, I have plenty of time to decide, thanks for the concern though, I will in fact, keep in the mind melted mess. Honestly kinda scares me. lol
Old 01-19-2013, 12:16 PM   #36
being3
Modded ///Member
being3's Avatar
That might work for headers but not for most of the turbos. For example the HPF kit as mentioned before because it throws other codes which will fail u such as over retarded cam, crank trigger, no MAF etc...
Old 01-19-2013, 12:18 PM   #37
mattfarrington
My Ride: 04 325xi
I wasn't talking about the other codes, I was talking about the PSI kit, and going catless. Which that fix would allow me to pass inspection. As their kit will pass all tests, if it's catted. So fi I want to remove the cats, I get the LC-1.. program it, and I'll pass.
Old 01-19-2013, 12:19 PM   #38
being3
Modded ///Member
being3's Avatar
From what I understand he needed to pass a visual tech inspection for a certain class he ran in. I know some emissions tests include visual inspections.
Old 01-19-2013, 12:22 PM   #39
being3
Modded ///Member
being3's Avatar
This sounds like that will work... Although the Proefi apparently can run without any codes with there sensor module I'm not sure how well it works though.
Old 01-19-2013, 01:12 PM   #40
mattfarrington
My Ride: 04 325xi
Well, I decided to pass on the HPF M3 I wanted.. I'm not just looking for a clean to one play with or a bit, THEN bring the car to Max.PSI and have them install a nice kit.
