Oil Valve Gasket + First Post - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-17-2013, 12:06 PM   #1
Shockingtaco
My Ride: 2004 330I ZHP
Just purchased my first car, 04' 330i ZHP, extremely happy with car and i'm excited to be able to join the community! Just have a question hope you guys could offer me some advice.
I just recently purchased a 330i zhp and so far I'm really happy with it, I took it in to get an inspection the other day and everything seems pretty much fine except for the oil valve gasket which has a slight leak onto the heat shield. I noticed this pretty much as soon as I got the car, mainly just a faint smell of oil after the car is off, no leaking, no smoke. Is this a problem I should repair as quickly as possible or something that doesn't need instant attention?
Shockingtaco is offline   Reply With Quote
Old 01-17-2013, 12:12 PM   #2
My Ride: Lexus
Congrats and welcome. My best advice is to see the links in my sig and do it all--especially those items you have no proof of.
Old 01-17-2013, 12:54 PM   #3
trj
My Ride: 325Ci
Congrats on your new ride.
Its not a problem unless you run the engine with low oil for a long time.
Just check the oil level regularly, 5 minutes after you turn off the engine.
The oil light will come orange after you turn off the engine if you are about half a quart low, and oil light will come orange while driving if you are a quart low.
That is if the sensor is working correctly and you dont want to check the dipstick too often.
Leaky VCG is a well known problem for us, and I have tried many times to fix it on mine. Now, I just keep on topping up the oil till it gets warm enough to work on it. I will just change the Valve cover itself, since 2 sets of new gaskets didnt resolve the issue.
I'd say do VCG, spark plugs and VANOS seals together if you dont have records of the later two.
I like working on one side of the engine at a time.
Do a search on DIY for VANOS, VCG and spark plugs. You will get information on the part numbers and how to's.
Read Mango's thread and prioritize what you have to do first.
Sometimes Mango can go a little overboard on maintenance but he has saved many cars from potential disasters. So, do what you feel needs to be done after reading his threads. Mango
Old 01-17-2013, 01:10 PM   #4
Stinger9
My Ride: '04 330Ci
It's important to know to completely avoid the Victor Reinz replacement VCG.
These have a recent history of numerous leaks in short order after installation.
Old 01-17-2013, 01:11 PM   #5
trj
My Ride: 325Ci
+1 on that
I replaced the first victor reinz with elring gasket and still have a leak. Next will be OE gasket with a new VC.
Old 01-17-2013, 02:35 PM   #6
Shockingtaco
Thanks for the help, much appreciated, i'm thinking about switching the spark plugs , so far thats #1 on my list, should be pretty easy... However I will probably need to do a bit more research on the VCG DIY beforehand.
Old 01-17-2013, 02:55 PM   #7
Stinger9
My Ride: '04 330Ci
Of course you don't touch the VCG to do the plugs.
Old 01-17-2013, 05:15 PM   #8
borrelli49
My Ride: 323ci
i had a pretty decent leak coming from my valve cover gasket. i pulled it off and it broke apart like plastic. So i put a new Fel-pro on it last night. only took 45 min or so. anyone that does not know much about cars should be able to do it.
borrelli49 is offline   Reply With Quote
first post, maintenace, oil burning
