Old 01-17-2013, 01:51 PM   #1
bmwci323
My Ride: 00 323ci
New fuel pump died in 2 days.
Could there be any reason for this happening?
Was it just by luck , the pump was defective? Or is there any possibility of a different issue. The fuse and relay was switched around just for the heck of it.
I could also tap the pump to get it to work again.. But now, finnaly, it will not turn on.
Ideas?
bmwci323 is offline   Reply With Quote
Old 01-17-2013, 02:06 PM   #2
My Ride: Lexus
That's certainly odd. What happened to the old fuel pump? Try that one? or it failed too? What brand?
Old 01-17-2013, 02:29 PM   #3
Zell
Zell's Avatar
My Ride: so turbo wow
Hey, it's rare but I mean it can happen.
Send it back for a new one. Yuck, I bet that'll be a messy, sketchy smelling box Clean it out with brake clean good!
Old 01-17-2013, 04:05 PM   #4
scottjoh
My Ride: '99 323i & '02 540i
Is it really a failure of the fuel pump or is the fuel pump relay bad?
scottjoh is offline   Reply With Quote
Old 01-17-2013, 05:54 PM   #5
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
yeah check the relay and the fuse first.
Old 01-17-2013, 05:54 PM   #6
DOB2009
My Ride: 325i
That sucks man, try to replace it and get a refund together.
DOB2009 is offline   Reply With Quote
Old 01-18-2013, 11:36 PM   #7
bmwci323
My Ride: 00 323ci
Yeah, I got a new one in aswell..
First start with the new pump was rough.. The car sounded off.
My car was sluggish when accelerating, basically a fuel starvation issue..
When i tested the volts to the pump I was reading 10.5 , wasn't sure if that was correct.
It feels like this pump will die out again aswell.
Any ideas?
Relay? I changed them around and it didn't seem to make a difference. Although, I never figured which one was which.
Fuse, I also changed over.
I just don't get it
Old 01-19-2013, 01:36 AM   #8
jonesenberg
My Ride: '04 330i ZHP 6spd
Badly clogged fuel filter? Mileage?
jonesenberg is offline   Reply With Quote
Old 01-19-2013, 05:32 AM   #9
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
What brand is the pump?
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 01-19-2013, 10:37 AM   #10
bmwci323
My Ride: 00 323ci
Siemens VDO.
I replaced the fuel filter 8000miles ago.
Car has 98000 miles
Old 01-19-2013, 11:42 AM   #11
bmwci323
My Ride: 00 323ci
Well..
Now that I had a clear mind, I ran my car this morning.
As soon as u started it, I knew It was misfiring, plugged in the scanner.. Misfire cylinder 1.
As it turns out, yes of course my pump needed replacement, and it just so happened a misfire occurred un related which led me back to a pump issue , yet again.
I will do some pulling and proding later this afternoon.
