Engine & Performance
Old 01-17-2013, 07:06 PM   #1
caryalon
My Ride: 2001 325i
e46 Fan Clutch, Fan Blade, Shroud and Aux. (Pusher) Fan - $250 obo
Original BMW, all in good condition:
Fan Clutch - Part #: 11527505302 (11-52-7-505-302) This clutch engages the belt-driven engine fan when the engine is warm/hot, and dis-engages the fan when cold/cool. These commonly fail, causing the engine fan to not spin fast enough (or at all) when your car is stopped in traffic, causing engine to overheat.
11 blade 420mm Fan - Part #: 11521712058 (11-52-1-712-058) This fan is driven by the serpentine belt, engaged by the fan clutch. If you have bad motor mounts, it's quite common for the blades of this fan to make contact with the radiator or radiator shroud, essentially self-destructing the fan into many pieces. Be sure to get a new fan clutch, while you are replacing this.
Fan Shroud - Part # 17111436259 (17-11-1-436-259)
Electric Pusher Fan (In front of AC Condensor) - Part # 64546988913 (64-54-6-988-913) Auxiliary Pusher Fan Assembly - With Frame - Mounted in front of the radiator, referred to by BMW as the "Pusher Fan"
The auxiliary fan in your vehicle serves an extremely important role. When your car reaches temperatures that may be hazardous to your engine, the auxiliary fan moves air through the radiator to provide better cooling. Usually activated during times of stationary vehicle operation, it supplements the air usually driven through the radiator by driving down the road.
Pulled, working, good condition from 2001 BMW 325i.
Fan Clutch and Fan fits many 6 cylinder BMWs, including the following::
1989-1994 E32 735i/iL
1991-1995 E34 525i, 535i, M5
1992-1999 E36 3 series with 6 cylinder engine (M3, 325, 328, 323)
1997-2002 Z3 2.3, 2.5, 2.8, 3.0, and MZ3 3.2 (S52)
1997-2003 E39 5 series, 525i, 528i, 530i
1999-2000 E46 3 series 323i/Ci, 328i/Ci
2001-2005 E46 3 series WITH AUTOMATIC TRANSMISSION ONLY
2001-2006 X5 3.0
Pick up on Long Island, NY or will ship.
caryalon is offline   Reply With Quote
Old 01-19-2013, 08:04 AM   #2
caryalon
My Ride: 2001 325i
Bump
Old 01-21-2013, 03:19 AM   #3
E_arroyo46
My Ride: 330ci
How much are you asking for the whole package pm please..
E_arroyo46 is offline   Reply With Quote
Old 04-09-2013, 10:08 PM   #4
Dinan91
My Ride: e46
I know its a long shot but Im interested in just the fan shroud Part # 17111436259 (17-11-1-436-259) any chance its still available?
Dinan91 is offline   Reply With Quote
Old 04-09-2013, 10:15 PM   #5
caryalon
My Ride: 2001 325i
Sorry - just the fan blade and clutch left.
Old 04-09-2013, 10:17 PM   #6
Dinan91
My Ride: e46
Thanks for the response.
