Sponsored by BAVSOUND
Old 01-17-2013, 07:07 PM   #1
Marshmallow
My Ride: Ehhh...
Alarm Installed, Makes A Constant Beep?
Today, I was at the BMW dealer having my alarm installed. I bought a used OEM alarm and had it installed and coded. Everything works fine, except for the siren. When activated, it just makes a high pitched constant beep. It is very annoying and probably very good as a theft deterrent but extremely annoying. It is ear piercing! Can this be coded for a different sound by the dealer or do I have to buy a new one?
Marshmallow is offline   Reply With Quote
Old 01-17-2013, 07:43 PM   #2
GCoop
My Ride: '04 325xi
Sounds broken. Literally it seems
GCoop is offline   Reply With Quote
Old 01-17-2013, 07:49 PM   #3
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
Did u buy a used alarm on here from a fellow member? Also did your alarm siren box have a "ece"
Code?
I had the same problem but found the solution
sent from my HTC EVO+ using Bimmer App
Old 01-17-2013, 07:54 PM   #4
Marshmallow
My Ride: Ehhh...
That's what the dealer thinks, but it makes the same sound that a heard on Youtube, only constant and much louder.
Code?
Yes, I did buy it used from a member, but I'm not trying to pin this on them, because I don't think they knew of the problem. Is the ece code on the sticker?
Old 01-17-2013, 09:42 PM   #5
eneka
My Ride: 2003 325i
you have the European alarm, it only makes the electronic beep when the siren is activated, it can be programmed to be continuous or at an interval
eneka is offline   Reply With Quote
Old 01-17-2013, 10:30 PM   #6
Marshmallow
My Ride: Ehhh...
Thanks for this, I'm going back to the dealer tomorrow and this will help.
Old 01-18-2013, 06:15 AM   #7
flashmeow
Banned User
i think I bought the same alarm from the same member. mine has the ece sticker and thus it has the continious beep. the alarm sound can be programmed
Old 01-19-2013, 03:22 PM   #8
Kmoy2002
My Ride: 2002tii, 540i, 330i
Yes, the alarm sound can be programmed. Under "Alarm Acoustics" select continuous tone. The other option will give you that beep like the video above. I tested both when my alarm sound differed from my e39 when I had the e46 alarm retrofitted.
Kmoy2002 is offline   Reply With Quote
Old 01-19-2013, 10:19 PM   #9
Marshmallow
My Ride: Ehhh...
Unfortunately I had to have the dealer do it because I don't have that program. Where did you get it? I can't seem to find one that will work with a Mac.
Old 01-19-2013, 11:15 PM   #10
Kmoy2002
The program shown is PA Soft. Works ideally with Windows XP. Does work with Vista and 7 with work. Some have gotten it to work on their Mac via running Windows via BootCamp. Either that or purchase a cheap laptop at a garage sale or ebay. Can be had for less than $100 if you shop around. The device and the laptop will pay for itself in a matter of uses.
Old 01-20-2013, 07:29 PM   #11
Marshmallow
My Ride: Ehhh...
Thanks for the info I'm definitely getting this now!
