Sponsored by The Tire Rack
Old 01-17-2013, 11:24 PM   #1
TF3N
My Ride: '02 325i 5spd
Different Diameter in Front vs. Rear?
Is it okay to run a different overall diameter in the front than the rear?
Example
Front: 225/35/18
Rear: 255/35/18
From what I've seen, it shouldn't be a problem(people run staggered set-ups all the time) - I just want to be 100% sure.
Thanks,
TF3N
TF3N is offline   Reply With Quote
Old 01-18-2013, 01:51 AM   #2
TF3N
Nobody?
Old 01-18-2013, 02:09 AM   #3
kleen'n'simple
My Ride: E90
http://forum.e46fanatics.com/showthread.php?t=687918
kleen'n'simple is offline   Reply With Quote
Old 01-18-2013, 02:14 PM   #4
2003 325i
My Ride: '03 Orient Blue 325i
so the answer is no.
225/40s up front and your fine.
The more it is off, the more your DSC will kick in. Terrible idea in the winter especially.
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 01-18-2013, 02:23 PM   #5
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Get a 225/40/18 up front instead of a 225/35/18.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 01-19-2013, 09:23 AM   #6
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
The more it is off, the more your dsc will kick in. Terrible idea in the winter especially.
+1.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 01-28-2013, 06:38 PM   #7
TF3N
Thanks guys.
I ended up not going with the set anyway. I'll be sure to match the diameter in the future.
Just out of curiosity, does the same rule apply if the car is equipped with ASC rather than DSC? From what I've been told ASC has no control over the front wheels.
Old 01-30-2013, 01:09 AM   #8
2003 325i
Same rule applies for every car with ABS regardless if they have stability control or not unless it can be programmed in to the ABS strategy somehow by a 3rd party aftermarket.
