E46 Xi Forum
Old 01-17-2013, 11:39 PM   #1
belmarBMW
My Ride: 2002 330xi
Is this a bad wheel bearing????
Is this bad or just normal play? it spins fine and feels fine while I am spinning it
belmarBMW is offline   Reply With Quote
Old 01-18-2013, 08:12 AM   #2
Kubica
My Ride: 2003 325xi
Looks like it.
Is it noisy?
Old 01-18-2013, 09:07 AM   #3
belmarBMW
My Ride: 2002 330xi
do you mean when I spin it? It is quiet and smooth. no binding. The other side has about the same play too
Old 01-18-2013, 10:51 AM   #4
Kubica
My Ride: 2003 325xi
When the wheel is mounted, do you get the same amount of play when you shake it?
I meant is it noisy when you are cornering?
Old 01-18-2013, 12:51 PM   #5
belmarBMW
My Ride: 2002 330xi
Its hard to say I had a bad rght lwr control arm bushing and balljoint and torn cv so I am replacing all the joints in the front end. both sides are apart. I also found a small chip off the chrome on the outer edge of the bearing race. I will post a pix soon.
Old 01-18-2013, 12:54 PM   #6
belmarBMW
My Ride: 2002 330xi
quiet on corners. terrible shake on high speed braking
Old 01-18-2013, 12:57 PM   #7
belmarBMW
My Ride: 2002 330xi
this is my next easy task. notice the bolt w/ no head. Like me!!
Old 01-18-2013, 03:21 PM   #8
Kubica
My Ride: 2003 325xi
^ouch that sucks.
Might as well do motor mounts if you need to drop the subframe to drill that out.
I would replace all of those bolts, the subframe bolts, and the strut pinch bolts too.
Old 01-18-2013, 04:31 PM   #9
belmarBMW
My Ride: 2002 330xi
don't wanna drop subframe. I was thinking of using the cyllinder the bolt threads into as my center. I was thinking of making a drill guide that slides over tubes and then I will have the right drill angle and close to center if not right on.A notched tube whose id matches the od of the mount.
