Old 01-18-2013, 10:28 AM   #1
boongsin12
My Ride: none
No click from starter motor, EDIT: there is a click. 2ND edit
For the last few days, I have been getting a weird symptoms on my 01' 330 ci, with 12x,xxx miles. When I try to start the car after its been parked for a while, it refuses to start. I hear no click from the starter motor. After a several tries of turning the key, all of sudden, the car starts with no problem, there is no hesitation in turning over the engine. This has been happening for the last two days.
I have checked my battery, which is only 6 months old, fuel pump, which is only 2 years old and all the connections. So, I don't think it's battery, fuel pump or the connection problem. While I was able to check these items, I wasn't sure what else I can check and how I can check them. For instance, how do I know if my alternator/voltage regulator is bad? Also how do I know if the clutch switch is bad? Most importantly, is my starter motor going bad? What should I examine?? Thanks in advance for your input!
EDIT: There is actually a click! I couldn't hear it well but it clicks everytime the key is turned.
boongsin12 is offline   Reply With Quote
Old 01-18-2013, 10:47 AM   #2
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
Sounds like it could be a switch problem or the battery is going bad. Others more knowledgeable than I will kick in their thoughts as far as troubleshooting.
HacksawMark is offline   Reply With Quote
Old 01-18-2013, 12:37 PM   #3
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
It would not be a bad alternator that would affect your starting, it would affect the charging of the battery.
To check your alternator, start your car and measure you voltage at your +B terminal. It should read 13.7-14.3 Volts.
BMWCaptain is offline   Reply With Quote
Old 01-18-2013, 01:09 PM   #4
havnfun328
My Ride: '99 328i, '03 M5
Sounds more like the starter solenoid.
2003 E39 M5 Lemans Blue: Truly an amazing car
1999 E46 328i Bone stock 5-speed: Beater and Track Car
250K!!!!!!!!!!!!!!!!!!!
havnfun328 is offline   Reply With Quote
Old 01-18-2013, 01:16 PM   #5
boongsin12
My Ride: none
Argh, I was afraid that the starter was the problem. I think i am gonna have to take this one to the local shop. Thanks for your input
Old 01-18-2013, 02:16 PM   #6
pleiades
My Ride: M52TU
Originally Posted by boongsin12 View Post
........I have checked my battery, which is only 6 months old, fuel pump, which is only 2 years old and all the connections........
If the clutch switch were going bad, there's actually a way to defeat it by looping a piece of naked wire through two of the three plug holes. I'll try and find the "DIY" (lol) for that. You'd lose the safety feature of the (functional) switch but lots of people hate that feature anyway.
Another potential culprit would be the oil level sensor connector (bottom of your oil pan, have to crawl under the car).
You might also want to disconnect your batter neg terminal and re-check all the main connections and grounds in the engine electrical system. There are several major grounding points. I don't have an e46 but my e39 has a few critical grounding wires bolted to the chassis, near the battery (neg cable base) and underneath or near the strut towers.
pleiades is offline   Reply With Quote
Old 01-18-2013, 02:26 PM   #7
boongsin12
My Ride: none
How exactly would the oil level sensor affect the turning of starter motor? I will double check the grounds and connection just to make sure.
The reason I kind of settled on for the faulty starter motor is due to this link. I am having a very similar situation.
Old 01-18-2013, 02:44 PM   #8
pleiades
My Ride: M52TU
The oil level sensor connector .... haven't experienced this myself but have been told a faulty or loose oil level sensor can prevent the car from starting. Maybe a myth?
BTW, did you actually check the connectors on the starter solenoid to ensure they're not loose?
Old 01-18-2013, 05:42 PM   #9
boongsin12
My Ride: none
I checked the positive connector under the hood. I haven't checked the physical connection on the solenoid, as I don't have means to get in that deep.
Old 01-18-2013, 06:05 PM   #10
328ci906
My Ride: 2003 M3
Starter solenoid isn't engaging. That's the click that you normally hear.
-2000 E46 328i
-2006 E60 M5
328ci906 is offline   Reply With Quote
Old 01-18-2013, 08:19 PM   #11
boongsin12
My Ride: none
Hi again!,
So, I got out of work this evening, and tried to turn on my car. Because I only had intermittent problem with starting, I though after a few times of trying I would be able to start the car. But no no no no. It didn't start.
Fortunately, the car was parked in a slight incline. So, I was able to drop it into a gear and got home. After I got home, I turned the car off. Now, I tried to turn on the car again. It started without a problem. My guess is that there is a residual current or whatever that makes the car turn on right after the car was shut off.
Now, I am kind of stumped because I thought the starter was gone and the car was able to turn over immediately after the car was shut off. What about that? Has any one got some ideas?
Old 01-18-2013, 08:25 PM   #12
DRE97
My Ride: 330CiC and 328 Xi
Hi again!,
Dumb question,
Would a scan tool help find the problem?
DRE97 is offline   Reply With Quote
Old 01-18-2013, 08:37 PM   #13
boongsin12
My Ride: none
Hmmm
I never thought about that as there is no cel light. But I guess that is a good place to discover.
Sent from my Nexus S 4G using Bimmer App
2001 330Ci
Old 01-18-2013, 09:20 PM   #14
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Get your voltage of car off and on.
I suspect it's nothing but your driving habits. You're taking a lot of short trips and no longs ones. Maybe the radio and lights are on while the car is off...the battery is just barely above the amps it needs to start. You jump started it, drove it home, then tried to restart it...I think you're right...it had enough juice then. If you tried again, or maybe twice, bet you'd run into an issue again.
If you have a charger, put it on...if not, next time you start, drive 20 mins. on highway at least...without radio, etc. on.
If your habits are good, then look into the fsr...well known for going bad and draining battery overnight.
GL...hth
Upcoming comedy shows: May 20, Greenwich Village Comedy Club. 6 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 01-18-2013, 09:41 PM   #15
boongsin12
My Ride: none
Well,
The issue has been persisting for at least a couple of days. Since then, I checked the battery voltage, which is 12.1V off 14.0V on. I don't suspect FSR is bad again, it's only 5 months old... I do drive relatively short distances but not too short.
How durable are the starter motors on our cars? I feel like it is a little premature for the starter motor to go dead at 125,xxx miles. It's that or there is a connection issue which is not obvious to find, I feel like.
Old 01-18-2013, 09:58 PM   #16
dmax
dmax's Avatar
Well,
Grounds from engine, battery...remove the battery and check that connection...under +terminal under hood, pull up on bat cables...they may be loose, read up on bst (that gets squirrley).
Ignition switch, starter both fail intermittently...and yes, it's early for a starter...at least, I know mine is still good, and I bet it's original...(we'll see).
12.1 V on the battery after how long it'd been off? Put on the radio and see if the voltage drops...then lights...measure voltage. See if you can get a sense of the amps it has.
I have a one year old battery, new alt putting out 13.9 -14 V.
After driving, I turn off car, V starts then around 12.7 and soon stabilizes at 12.3. I could listen to the radio for hours. Once it's at 12.3 it stays there for a long while.
Corrosion and looseness of cables. If you use a lot of power...have aftermarket stuff installed, subs for your radio...your battery might be good, but just nearly drained. See CCA rating on your battery and get it professionally load tested...needs to be a sizeable machine to do a proper test...not a little handheld that autozone guys might use.
$50-60 gets you a trickle charger...or borrow one from someone.
Mangofy your E46!
Old 01-19-2013, 10:15 AM   #17
boongsin12
My Ride: none
At first, I was very skeptical that the battery is already bad considering it being only 6 months old. So, this morning I checked the battery voltage. From the trunk compartment, I got 12.2V and from the engine compartment battery positive terminal, I got around the same 12.2V. So there is no issue there.
One thing that puzzles me the most is that the car started this morning without a problem. Turned the key and it fired up right away. It wasn't the case yesterday morning and last night.
I remember I had a slight problem with battery connection in the engine compartment 5 months back. Back then I solved the problem by replacing the wing nut that holds the positive terminal together. I did check it this morning and it wasn't loose. However, I didn't check the connection from there to the starter, which I have no clue how to check.
Old 01-19-2013, 10:22 AM   #18
Orchazum
My Ride: Steel Grey 330i
This happened to my car very recently. It ended up being the positive terminal under the hood. I verified this by unscrewing the nut. Tried to start it, but did the same thing. Cleaned off the nut and connection made sure everything was secure and BOOM! If you havnt tried this please do so.
Sent from my SPH-L710 using Bimmer App
Multi Color Angel Eyes, MD, K&N, Sharked, Y-Rated Shoes
Orchazum is offline   Reply With Quote
Old 01-19-2013, 10:23 AM   #19
Orchazum
Sorry just read the post above me
Old 01-19-2013, 10:26 AM   #20
boongsin12
My Ride: none
One thing I didn't do is cleaning the cable connection... this might be worth it. Would it be possible that the connection is dirty and corroded hence no start? Another funny observation, which I am not so sure it is relevant, is that I seem to have hard time starting the car when the weather is relatively cold, below 20F. This morning was definitely above 35F.
