Old 01-19-2013, 10:29 AM   #21
Orchazum
My Ride: Steel Grey 330i
I would clean the connection. I scraped mine with the connector and figured out it was that... A lot of stuff came off. A lemon or a steel brush would work. Let me know if that works
Sent from my SPH-L710 using Bimmer App
Multi Color Angel Eyes, MD, K&N, Sharked, Y-Rated Shoes
Orchazum is offline   Reply With Quote
Old 01-19-2013, 06:55 PM   #22
boongsin12
My Ride: none
Yup... I think cleaning the battery contact did the job. I took a sand paper (grid 120) and cleared the contacting surfaces with it. It makes me wonder if the corrosion was the problem or if my starter is slowly failing.
As for the corrosion protection, what is the recomended method? You mentioned about lemon juice? How do you use that?
boongsin12 is offline   Reply With Quote
Old 01-20-2013, 01:35 PM   #23
Orchazum
I used an actual lemon the same way you would clean corrosion off a battery terminal. Now whenever I change my oil I will just check the terminal.
Old 01-24-2013, 10:10 AM   #24
boongsin12
My Ride: none
Okay,
I don't get this. This morning I had this same problem once again. Th problem was that the starter clicked but did not turn over. So, knowing what happened last time I went over to the battery terminal and checked if the connection is tight or not. It was tight and there was no corrosion like last time. I reconnected the cable and tried to start the car. The car turned on with no problem.
The problem is why does the car not start even though the battery connection is good (battery is good, 12.1V off, 14.1 on) unless I physically disconnect and reconnect it? Do you think there is some problem within the electrical wires going from the terminal to starter? That's the only explanation I have at this time.
Old 01-24-2013, 10:18 AM   #25
DRE97
My Ride: 330CiC and 328 Xi
Originally Posted by boongsin12 View Post
Okay,
Not so sure it is you battery.
If all the lights, radio and stuff go on but you only get a click at the starter, it usually means a starter problem.
All the lights are working, right?
DRE97 is offline   Reply With Quote
Old 01-24-2013, 10:28 AM   #26
boongsin12
My Ride: none
Yes, all the lights are working. You are saying that the starter may be going? I am able to start the car with no struggle. Doesn't this suggest that starter is fine?
Old 01-24-2013, 10:47 AM   #27
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
I'm certainly no expert on this matter but from what you're saying, you have an intermittent problem with the starter not receiving enough current to turn it over (not meaning to state the obvious, just thinking out loud...). That leaves in my mind three possibilities, the source (battery), the connection/s, or the starter itself. If you can verify two out the three as being rock solid in condition, the remaining one should be the culprit. Unfortunately, you will have to spend some $$ in figuring this mystery out since the current troubleshooting process is not working. My guess would be the starter itself since it seems you're certain that the battery and connections are good.
HacksawMark is offline   Reply With Quote
Old 01-24-2013, 10:53 AM   #28
DRE97
The starter probably has a warn area inside the motor and sometimes when you turn the car off you are stopping the starter at that exact spot, other times your not and the car starts.
Old 01-24-2013, 11:19 AM   #29
scarede46er
My Ride: 2001 BMW 325i ZSP
Don't discount the possibility that your key or ignition switch might be going bad. The key does get worn down and the ignition lock mechanism is iffy sometimes.
Old 02-07-2013, 09:35 PM   #30
boongsin12
My Ride: none
So, after a few days of trouble free driving, the issue started to reoccur. The exact same symptoms as before.
Now, here is the funny bit. I found out that when the starter motor does not turn over, I open the hood latch and immediately following the starter motor turns. What is going on?!?!?! Any possible reasons?
As always, Thanks for all your response.
2001 330Ci
Old 02-07-2013, 09:40 PM   #31
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
A ghost?
BMWCaptain is offline   Reply With Quote
Old 02-07-2013, 10:00 PM   #32
HacksawMark
So are you saying that the act of opening the hood latch causes the starter motor to turn over on its own? Or are you saying that after you've opened the hood, you try starting it again and it works? Either way, sounds like a loose/bad connection somewhere or it's the starter itself. My money is on the starter....
Old 02-07-2013, 11:16 PM   #33
TurnersInOz
My Ride: 2004 325i
Starter / solenoid
TurnersInOz is offline   Reply With Quote
Old 02-13-2013, 01:49 PM   #34
Orchazum
I had the same issue.upon shutting my hood, it would start. You have an interesting problem though
