The Tire Rack's Tire & Wheel Forum
Use this forum to discuss anything in relation to wheels to tires to offsets. Sponsored by The Tire Rack |
#41 |
Sh1tty Advisor
My Ride: 323Ci 5 Speed Black
I am sorry, I was on the wrong forum for 2 years.
![]() Oops! My Water Pump Broke Again .................... Coolant in a Bottle |
#42 |
Ha ha, what I meant was Wouldnt an e36 be quite different than an e46?
#43 |
Nope. Not in terms of wheel offsets.
#44 |
Why is his offset 20 and mine is 49 then
#45 |
Well lets ask this. Which wheels do YOU like the most?
Follow Me On Instagram: JamesMarshall_E46 ![]() My Progress Thread - How To Set a Signature - Black Sedans FTMFW -James- |
#46 |
To finalize, I just got the style 5's. they're at my doorstep as we speak
#47 | |
Sorry I missed this post.
Well he might have wanted the ET20 wheels and purchased them. I dont know what are you asking here? How can I answer why he has offset 20 wheels? Even if he is running ET0 or negative ET, I wouldnt be able to answer WHY. Offset and wheel width plus tire width go hand in hand. You have to really calculate when you are deviating from the standard wheel size. Quote:
Did you measure the ET like I asked you before? Post the pics when you fit them. I found a good deal locally, but they are from e39 so I passed.
#48 | |
#49 |
ET is offset. You bought the wheels without doing proper research. Hopefully you won't have problems.
#50 |
ET is 23. I knew the offset. I just didnt know what the term meant.
#51 |
You should be fine as long as you get the right tires. Is your suspension stock? I'm running the same wheels in 17" on H&R cupkit, rolled fenders, and 225/45/17 tires. I have no problems with the exception of slight rubbing (on the rear bumper where its near impossible to roll becuase the lip is so small) with a full load and bad roads. Although I think sedans have slightly less room for clearance, I doubt you will run into any problems.
#52 | |
#53 |
Post some pics with them mounted now.
I really want to see how they look.
#54 |
MR.CLEAN ;)
I don't think they will look as good as your wanting them to unless you lower your car
#55 |
It'll be a while, it's winter here and I'm touching them up while I wait for the weather to change up.
#56 |
Do you have any pictures of the Elbrus I08s on your car?
#57 |
I'm considering the I08s as well
I found this picture on a 5-series
Tire Rack suggested them because they are pretty similar to M3 rims and they can put a BMW logo on them. |
#58 |
