Sponsored by The Tire Rack
Old 01-19-2013, 12:49 AM   #1
fuzzykeeghan
My Ride: 2003 330Ci
Z4 Style 107 wheels
Hi guys,
I'll just come out and say that I don't get wheels at all. I've got a facelift 330Ci with the standard 17" wheels (style 117).
Will these Z4 wheels work without the need for adjustments? Just "plug and play" if you will?
http://www.ebay.com.au/itm/130835843...9#ht_500wt_899
Thanks for the help!
fuzzykeeghan is offline   Reply With Quote
Old 01-20-2013, 03:56 AM   #2
JS330
My Ride: '01 330Ci 3 Pedals
haha I was looking at these as well man, might go test them tomorrow but undecided how it'd look on the e46 at this stage
Originally Posted by DeclanM3 View Post
I hope he isn't using Pirelli condoms..
JS330 is offline   Reply With Quote
Old 01-20-2013, 03:57 AM   #3
JS330
and they are bmw style 202
Old 01-20-2013, 04:13 AM   #4
2003 325i
My Ride: '03 Orient Blue 325i
OP is right, they are 107s not 202s.
They will fit, I'd run 10-15mm spacers front and rear but should plug and play.
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 01-20-2013, 06:46 AM   #5
JS330
http://www.bmwstylewheels.com/bmw/202
Old 01-20-2013, 10:37 AM   #6
2003 325i
have you looked at the 107s even? Look at the shape of the holes buddy. 202s ovals, 107s round. The ad he posted has wheels with round holes.
Old 01-20-2013, 09:17 PM   #7
Euro604
My Ride: 2002 330Ci
107s and 202s are reeaaaallly close. Had to compare em side by side to tell the difference. I prefer the 107 tho. Cleaner looking wheel.
2002 330ci, Scwartz Black, AFE Intake, Muffler Delete, 18" CSL Replicas
Euro604 is offline   Reply With Quote
Old 01-20-2013, 09:57 PM   #8
JS330
My mistake, yeah I thought they were the same until I saw the oval and circle in the detail!
Old 01-20-2013, 09:57 PM   #9
CharlzO
My Ride: 2000 328ci
They are the 107s in the listing. Can tell by the smoother areas around the lugs, if nothing else.
CharlzO is offline   Reply With Quote
Old 01-21-2013, 12:13 AM   #10
fuzzykeeghan
My Ride: 2003 330Ci
Will putting these wheels on make my speedo inaccurate to some degree? Will I need to get it recalibrated?
EDIT: Just looked at some online calibrators, and it said that it would be going .45% faster on the front wheels and 1.4% faster on the rear wheels, which wheels are the odometer readings coming from? Or is it not that simple?
Old 01-21-2013, 02:30 AM   #11
2003 325i
should be 255/35s on your rear. Won't change your speedo enough to matter.
