E46 Xi Forum
Old 01-19-2013, 11:54 AM   #1
caleb6
My Ride: 2005 330XI
vibration with "thump, thump, thump" sound
I've been researching this, but don't seem to see a discussion matching my symptoms. I'm a noob when it comes to car work, but learning fast.
Anyway, on heavy acceleration in 1st, 2nd and sometimes 3rd I get a vibration and sound from what sounds like right underneath the center armrest. It's related to RPM, and comes around 2900'ish and then again at 3700'ish. THere is a very solid rumbling type sound accompanying it.
Like I said, I'm a noob when it comes to this stuff, I'm hoping someone can say oh yea, that your U-joints or something.
thoughts?
Thanks!!
caleb6 is offline   Reply With Quote
Old 01-19-2013, 12:00 PM   #2
E46Moonlight
My Ride: 2000 323i
Search guibo
E46Moonlight is offline   Reply With Quote
Old 01-19-2013, 12:01 PM   #3
caleb6
My Ride: 2005 330XI
Originally Posted by E46Moonlight View Post
Search guibo
read all about it, but that's further upfront isn't it? And, mine looks in pretty good shape.
Old 01-19-2013, 12:04 PM   #4
caleb6
My Ride: 2005 330XI
Search guibo
by the way, what type of AE's do you have, and are they on A/L headlights?
Old 01-19-2013, 12:04 PM   #5
E46Moonlight
My Ride: 2000 323i
Then maybe the center support for the driveshaft
Old 01-19-2013, 12:05 PM   #6
E46Moonlight
My Ride: 2000 323i
I have Umnitza Orion V2s one stock bi-Xeon headlights
Old 01-19-2013, 05:53 PM   #7
Kubica
My Ride: 2003 325xi
I would change the transfer case fluid and front diff fluid.
Have a good look at transfer case mount, look for bent wheels, check tire pressures, etc.
Old 01-20-2013, 03:30 PM   #8
caleb6
My Ride: 2005 330XI
changed all those fluid less then 10,000 miles ago. Wheels are good, and its not tire pressure dependent.
I'm thinking it may be the transfer case rubber buffer, number 2 below. I'm gonna replace it and see
Thanks for the help!
Old 01-20-2013, 03:39 PM   #9
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Before you give up on wheels...did you look at them for flat spots? Even if balanced, you can have a flat spot you'd feel. Spin each wheel by hand and look at the rims for a 'hop' indicating flat spot. If you find that up front, move it to the back.
Often times tire balance issues show themselves at a particular speed...and you can often drive up to them and past them without issue...but there will be a range where you'll notice it...and it would vibrate the whole car...so you could think it's coming from anywhere really.
You can see part of the guibo...but if you look closely, see if the metal spacers through the guibo are firmly attached to the rubber. It might look from from the outer edge, but not be where the bolts go through. Take a close picture of it for us.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 01-20-2013, 07:40 PM   #10
caleb6
My Ride: 2005 330XI
OK, here are some close ups of the GUIBO:
ID:	486911   Click image for larger version
ID:	486912   Click image for larger version
ID:	486913   Click image for larger version
Old 01-20-2013, 07:41 PM   #11
caleb6
My Ride: 2005 330XI
And here is the transfer case buffer I think I will replace:
ID:	486915   Click image for larger version
Old 01-21-2013, 10:49 PM   #12
325xittt
My Ride: 2003, 325 XIT
I'm guessing the center support bearing.
325xittt is offline   Reply With Quote
Old 01-22-2013, 02:35 AM   #13
caleb6
My Ride: 2005 330XI
Are you saying part number 9 below or number 8 which appears to be the carrier AND the bearing as one unit?
Old 01-22-2013, 07:38 AM   #14
325xittt
I'm guessing its the carrier number 8. The bearing 9 floats in a rubber membrane in the carrier housing. I'm guessing that has deteriorated. Dont forget item 11 a thick sticky gooey double sided tape that helps stabilize the carrier. Also the Bently manual say to pre-load the bearing by sliding it back (?) about 10 mm before tightening the mounting bolts all the way. You should consider replacing item 1 (guido) since it has to be removed to get to the bearing. Match mark your splines at both end before removing the axle. I used a oil filter strap wrench to loosen the item 5 locking collar
Old 01-22-2013, 07:54 AM   #15
caleb6
My Ride: 2005 330XI
You did this job already? You're close to me. Maybe a case 'a beer help a brother out deal here? Just someone to stand by and give support, with an educated sense of what it's suppose to go like, would be a huge benefit.
Old 01-22-2013, 07:59 AM   #16
Kubica
My Ride: 2003 325xi
^the CSB is probably fine. I'm not sure why everyone wants to replace them all of a sudden.
Check to see if the rubber has pulled away from the metal center of the TC mount at all. If so, replace it. The guibo looks fine.
Rotate your tires front to rear and see if anything changes.
Old 01-22-2013, 08:48 AM   #17
miweber929
My Ride: 02 330xi
I' guessing it's because I replaced mine. This forum is the most monkey-see, monkey-doo place I've ever visited; if someone has a P0174 code they think they NEED to replace the DISA because someone mentioned the did that and the code went away so that's the accepted fix now......
OP, the last 2 things Kubica mentioned are probably a bigger factor and a better place to start. The TCB is a PITA to do according to the shop but made the biggest difference in my vibration of the car and overall solid feel. The XI has no other transmission mounts than this, so it's imperative it's tight.
miweber929 is offline   Reply With Quote
Old 01-22-2013, 01:43 PM   #18
caleb6
My Ride: 2005 330XI
Thanks guys. The rubber on the TC mount did look pretty bad internally - cracks and definately "dryed" out looking. I'll look into replacing it (have one ordered already anyway) and rotate the tires and see what that does.
Anything to look out for when replacing that TC mount rubber? Like preloading the CSB to the driveshaft removal type things to watch out for?
Old 01-22-2013, 05:24 PM   #19
ixtoxi
My Ride: 02 330xi, 88 325iX
Have you absolutely ruled-out the CV axles up front? Sometimes it is hard to tell where the vibration is coming from when these are the problem. Does your vibration issue happen when you first start out on a drive, or only after driving for a while?
ixtoxi is offline   Reply With Quote
Old 01-22-2013, 05:41 PM   #20
dmax
dmax's Avatar
Why doesn't your guibo have 6 nuts on it? Also the e-bolts you have don't belong on the guibo afaik, but on the other end of driveshaft. But, there should be nuts on each of the bolts. Looks like yours only has 3 nuts on. Did this issue happen after you'd had guibo replaced recently?
Ah, the wrong bolts are too short for you to get nuts on...that's one thing...didn't think that flange was threaded, but it still takes nuts on mine...check realoem for your car and make sure you get that part right.
Mangofy your E46!
