E46 Xi Forum
Old 01-24-2013, 07:02 AM   #41
325xittt
My Ride: 2003, 325 XIT
OP
Hope you find your problem. Lots of good ideas from others. I look forward to hearing what solves solves your thumping problem.
By the way, as was pointed out so kindly above. I'm still looking for a TC. I've got 2 xi's, two different problems.
Peace, Out
325xittt is offline   Reply With Quote
Old 01-24-2013, 08:37 AM   #42
jeepo23
My Ride: 2008 X3, 6 Speed
Originally Posted by caleb6 View Post
OK. Thanks guys! TC mount buffer on the way. I'll update with results once changed out.
Yah I am changing out my TC mount here hopefully soon once the weather warms up a bit. let us know how it turns out!
jeepo23 is offline   Reply With Quote
Old 01-24-2013, 09:13 AM   #43
miweber929
My Ride: 02 330xi
Did you check to see if yours is bad before ordering? Throwing random parts at an issue without checking them first is a sure way if throwing time and money down the toilet.
This part does seem to be a source of vibration but if its not bad, why change it? Like Kubica said it takes 5 minutes to check and is fairly obvious.
miweber929 is offline   Reply With Quote
Old 01-24-2013, 11:18 AM   #44
caleb6
My Ride: 2005 330XI
Yeah dude, did you read the thread? Not only did I check it and mention the results above, I freakin' took pictures of it and posted them too. Come on!
caleb6 is offline   Reply With Quote
Old 01-24-2013, 08:00 PM   #45
miweber929
My Ride: 02 330xi
Yeah, I did.
Completely. Couple times even.
Fyi, the pictures really don't show **** and you were confused by front vs. rear guibo for some reason. So I was asking a legit question as it appears you're fixing random things left and right. I tried to maybe offer some help since I just went through all these replacements myself with mixed results but since you insist on being an asshat, well screw you then and have fun.
Old 01-24-2013, 08:54 PM   #46
caleb6
My Ride: 2005 330XI
Yeah, I did.
OK, thanks. Bye bye now.
Sent from my Galaxy 10.1 Tablet on bimmer app.
RIP Bach: 11/4/2003 - 3/9/2013
Old 01-24-2013, 09:35 PM   #47
countdown
My Ride: 2004 325xi
Id say it might be a torq converter.
countdown is offline   Reply With Quote
Old 01-25-2013, 04:08 PM   #48
caleb6
My Ride: 2005 330XI
anyone actually replace their own TC buffer? I've been searching but can't find anything - not on here, not on google, not on bavauto tech site.
it seems like it should be fairly easy, but I'd rather not get into it without a DIY to follow here.
EDIT: I'm on to some stuff now at bimmerfest. I'll keep this thread updated for posterity.
Old 01-25-2013, 08:30 PM   #49
e46alfonso
My Ride: 330xi MT, mustang gt
The TC is not repairable. What fluid are you using?
I must have dumped the clutch more than 50 times at around 3-4k rpm and my awd system is perfectly smooth. Doubt its the TC.
Vibrations during heavy acceleration sounds like axles. Are they original, OEM GNK, or another brand?
Old 01-26-2013, 06:00 AM   #50
caleb6
My Ride: 2005 330XI
I'm sorry man, but I don't understand your point? I'm not contemplating repairing the TC, just replacing the TC mount rubber buffer.
FWIW, I used RedLine MTL in the TC, following Mike Miller's advice. TC runs smooth as silk, as does the rest of the transmission. I just have a vibration at very specific RPM range.
Regarding the axles - I assume OE. I haven't replaced them, they look OE (although I haven't looked that hard), and I have no history on the car prior to my purchase.
Old 01-26-2013, 11:36 AM   #51
jeepo23
Here is what one member did to replace the TC bushing. This is what I plan on doing within the next month. Couple of plates, a rod, some washers. Use a reciprocating saw to cut the other sleeve of the old bushing to get it out.
Old 02-17-2013, 07:33 PM   #52
caleb6
My Ride: 2005 330XI
So to update this situation - after being sidetracked by my fuel pump going out and having to replace it, the fuel filter, and the fp relay, I'm back to trying to figure out this vibration thing.
I ordered, and received, the new TC mount bushing - haven't installed it yet. Today went for a 120 mile round trip with the wife and both kids. Noticed that the vibration is getting worse, and now showing up when downshifting or 'coasting' in gear - basically when not under load.
I guess I'll get the TC mount bushing replacement job complete and go from there.
Hope that's all it is.
Old 02-24-2013, 08:31 AM   #53
nosnooz
My Ride: 2002 325xit
I had the thumping sound on acceleration from a stop and it was the csb. The rubber had torn that holds the bearing to the csb mount. The driveshaft was free to flop around a bit.
nosnooz is offline   Reply With Quote
Old 03-25-2013, 09:05 PM   #54
325xittt
any updates
Hey caleb6 did the TC mount solve your problem?
Old 03-26-2013, 05:13 AM   #55
caleb6
My Ride: 2005 330XI
Hey! I didn't even get to it yet - had some other issues get in the way, like a failed fuel pump and filter replacement. I have the mount still, just haven't gotten around to replacing it yet.
Old 03-26-2013, 09:54 PM   #56
325xittt
Yeah I know the feeling. I got a set of replacement shocks from Bilstien sitting in a box. Life gets in the way. Let us know what you find out
