///M3 Forum
Old 01-23-2013, 08:04 PM   #1
E46Cherry
My Ride: 2003 M3
Suspension
I'm nearing 70k miles on my M and thinking about replacing my struts and coils. When did you guys replace coil springs and or both, and should I go oem or switch to coilovers? I was thinking PSS10.
E46Cherry is offline   Reply With Quote
Old 01-23-2013, 09:30 PM   #2
choxor
Fully Deeked Out
choxor's Avatar
My Ride: An Automobile
Unless your springs are damaged there is no reason to replace them. Shocks usually last around 60k miles.
Old 01-23-2013, 10:26 PM   #3
E46Cherry
My Ride: 2003 M3
I had my car check for rtabs and one of the recommendations was replace cool springs. So I assume they are towards the end of their life cycle
Old 01-23-2013, 10:40 PM   #4
choxor
Fully Deeked Out
choxor's Avatar
The life cycle for a spring is a long, long time unless they're badly corroded, broken, or sagging. By long time I mean they usually last the life of the car. They're not a wear item like shocks.
At 70k miles I doubt your springs are bad, but given your location I suppose it's possible. I'd get a second opinion before buying new springs.
Old 01-23-2013, 10:41 PM   #5
E46Cherry
My Ride: 2003 M3
and I said I was near 70k so well beyond 60k
Old 01-23-2013, 10:45 PM   #6
E46Cherry
My Ride: 2003 M3
Sorry, didn't see your post. So if anything, should I go oem or is this a good time to switch to coilovers?
Old 01-23-2013, 10:59 PM   #7
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
Switching to coil-overs is a personal decision. You can just replace your shocks with some koni shocks.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 01-24-2013, 10:56 AM   #8
illestminimike
My Ride: 2003 SMG Vert M3
What do you use your car for?
-2003 M3 Vert
-1967 Mini Cooper
Old 01-24-2013, 11:06 AM   #9
E46Cherry
My Ride: 2003 M3
dd
Old 01-24-2013, 12:03 PM   #10
illestminimike
Just replace shocks. If you want to lower your car get some lowering springs.
-2003 M3 Vert
-1967 Mini Cooper
coil spring, coilovers, strut, suspension
