Old 01-19-2013, 06:02 PM   #1
Kittepunch
My Ride: 2003 325xi
Anyone know where I cam get replacement fog light wires?
So I bought and HID fog kit with harness for my 2003 325xi and got everything installed properly. However, after fiddling with the housings to get them into place, the old wire that the fogs *used* to be attached to came loose and slipped right out of the connection.
I'm wondering if anyone knows where I can get a replacement connection/wire so I can splice it onto the old wire.
Here's a picture: http://i.imgur.com/siE9FEy.jpg
Kittepunch is offline   Reply With Quote
Old 01-20-2013, 01:34 AM   #2
christiandflores
My Ride: BMW M3 E46
are you just looking for the cable? or the cable with the plug at the end?
- Christian
BMW M3 E46 | Carbon Black Metallic | Gray Nappa | 6MT | SMG | 40% Tint | Full LED Interior/Exterior | Michelin PSS 275/30/19 square set up
https://www.facebook.com/SanDiegoBmwMeet
christiandflores is offline   Reply With Quote
Old 01-20-2013, 01:54 AM   #3
Kittepunch
My Ride: 2003 325xi
Cable with the plug.
Old 01-20-2013, 02:36 AM   #4
christiandflores
My Ride: BMW M3 E46
Is this what your looking for? I've got a couple of these that are pretty much new that I only used once for testing.
ID:	486831   Click image for larger version
- Christian
Old 01-20-2013, 05:36 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Go to an autoparts store and buy 9006 connectors. The wiring should be a good length too, cut off the OEM ends and solder/splice on the connectors.
