Sponsored by BimmerWorld
Old 01-19-2013, 06:19 PM   #1
hitmanre
My Ride: 2000 BMW 328i
just got an e46....2 days later brake pad light
okay so the brakes feel very smooth but the brake pad light is on. I guess i should replace them?
http://www.ebay.com/itm/Rear-Set-HIG...4bc290&vxp=mtr
does anyone think those are good or okay?
hitmanre is offline   Reply With Quote
Old 01-19-2013, 06:23 PM   #2
Zell
Zell's Avatar
My Ride: so turbo wow
Remember kids, just say "No" to eBay brake parts.
Old 01-19-2013, 06:38 PM   #3
wildirish317
My Ride: 2004 325Ci vert
The choice of brakes depends on how you drive your car (daily driver vs. track vs. whatever). There are several threads on this. Do a search. Replace the rotors when you replace the pads. Rotors are cheap and easy to replace. Don't forget to replace your brake wear sensor too. It's toast.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 01-20-2013, 10:20 AM   #4
hitmanre
Thanks man that was a lot of help! I'm buying a set of rotors and pads for 170 on ebay
Old 01-20-2013, 10:33 AM   #5
2003 325i
My Ride: '03 Orient Blue 325i
Brilliant, cheap out on the items that stop your vehicle. Not crashing is overrated.
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 01-20-2013, 10:40 AM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
+1.......
OP, good brands for brake pads are Jurid, Pagid, Textar, Akebono. For rotors there's ATE, Brembo, Zimmerman (my recommendation), Sebro
Old 01-20-2013, 10:40 AM   #7
jfoj
My Ride: 330CiC, M5, X5, E93
This may be a better idea??
http://www.amazon.com/Power-Stop-K49...ype=automotive
Check fitment/application.
Suggest you check out all my signatures as well as read the stickies at the beginning of the forum!
Old 01-20-2013, 11:47 PM   #8
hitmanre
Ah thank you for the replies Guys I'm ordering the one above now
Old 01-21-2013, 12:29 AM   #9
Guest021715
Account closed.
That would be a mistake.
Stick with OEM brake pads and rotors. There are literally dozens of vendors online where you could purchase them cheap.
Drilled/slotted rotors will only give you more headaches, harsh braking, and less contact area with the brake pad.
Old 01-21-2013, 01:15 AM   #10
DHK
My Ride: 2002 BMW 325Ci
Yes you have less contact but there is no evidence that drilled rotors effect stopping distances negatively and there are a number of not totoally scientific studies that suggest drilled rotors actually shorten stopping distances when they are warmed up.
Plus this guy is obviously looking to do this on the cheap and if he is going to go the cheap rout the kit jfoj suggested isn't half bad.
DHK is offline   Reply With Quote
Old 01-21-2013, 01:21 AM   #11
Euro604
My Ride: 2002 330Ci
http://www.ecstuning.com/BMW-E46-330...Kit/ES2515298/
This works as well. What I'm gonna order for my car
2002 330ci, Scwartz Black, AFE Intake, Muffler Delete, 18" CSL Replicas
Euro604 is offline   Reply With Quote
Old 01-21-2013, 01:25 AM   #12
patrickmurray2
My Ride: 2005 bmw 330i e46
I recommend you to stay away from ebay parts such as brakes, suspension, and any performance parts that are not named brand spend a little extra money on some good rotors and pads it will be better in the long run! Good luck
patrickmurray2 is offline   Reply With Quote
Old 01-21-2013, 01:37 AM   #13
Guest021715
Account closed.
Drilled and slotted rotors have the purpose to reduce brake fade on the track, and would apply to moreso to BBKs, not some small stock 325 rotors.
My 12 year old 325 outbrakes brand new cars and is running blanks.
A set of blank brembo rotors and OEM pads would cost the same as those no-name kits.
Old 01-21-2013, 01:39 AM   #14
2003 325i
bestpricecarparts.ca
Old 01-21-2013, 08:16 AM   #15
hitmanre
Dang I just ordered them ill see if I can cancel my order
