Thread Tools Search this Thread Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Old 01-19-2013, 05:33 AM   #1
Drizzles
My Ride: 1999 BMW 318i E46 4D
Problems post Engine transplant ... but I have codes!
Hey everyone ...
SO - long story short, just put another engine in my car, after doing a big end bearing on my old one with 212,000kms on the clock.
About $2000AUD later, my mechanic friend and I have the new Engine in the car, with only 82,000 on the clock.
She now runs!! She's driveable!! But I still have a few issues ...
I have both a PASoft Code Reader and a Peake Tools reader.
The Peake reader shows, "Control Unit Self Test" - "Signal Throttle Potentiometer" - "DISA Valve Suction"
Now, the PASoft reader gives a much more compehensive report (see below).
In addition to this, I KNOW I have something wrong with my Transmission (I've had it play up before but got away with a filter & oil change and it worked fine again) this time it's leaking oil and is sluggish and is somewhat jerky when changing gears.
Lastly, my Traction Control light is stuck on. Won't go off. I know this can be 20 million things, some things even point towards Transmission, but I really don't know. Can someone point me in the right direction here?
Oh, also, I have an engine full of spare parts, if that helps at all
Thanks peeps
BMW Scanner v1.4.0.6 (24.05.2008) - P.A.Soft, 2008 HW: V144Bn9 Time: 19:41:12 19.01.2013
ZCS coding : /-------- IKE --------\ /-------- EWS --------\
Chassis : E46 E46
Model : 318i 318i
Type key : AL32 AL32
Engine : M43B19 M43B19
Gearbox : Automatic Automatic
VIN : FH55319 WBAAL32040FH55319
ZCS GM : 65321010-5 65321010-5
ZCS SA : 000088000D200088-D 000088000D200088-D
ZCS VN : 00000000CB-E 00000000CB-E
# SCAN START
Unit BMWTNR HW SW-FSW CI DI BI/VI Date Odometer VIN ADFG Algorithm
DME -> 1.430.940 61 F0 00 A7 60 07/11 212670 km WBAAL32040FH55319 000000 BMS46 M43 EU3
EGS -> 1.423.279 23 57 00 70 60 xx/xx - WBAAL32040FH55319 000000 GS8.34
EWS -> 8.382.452 02 05 81 81 07 32/98 212676 km WBAAL32040FH55319 FFFFFF EWS3
ABS -> 1.164.896 04 20 03 69 60 28/78 - - 005319 ABS/ASC MK20 E36,E46
A/C -> 8.382.446 10 04 02 31 00 35/98 - - 005319 IHKA E46 PU98/PU99
SRS -> 8.372.521 02 30 07 07 00 32/98 - FH55319 000000 MRS2
IKE -> 8.380.146 04 07 02 50 08 32/98 212675 km FH55319 FFFFFF 93S66 - E46 (E46)
LCM -> 8.383.225 06 11 27 20 00 32/98 212600 km FH55319 000000 HC11P2 - 4 (LSZ)
ZKE -> 4.533.551 10 11 01 40 08 33/98 - - CC5319 ZKE5
RAD -> 8.368.254 43 44 00 14 09 20/98 - - - Radio ZIS/BM/MIR
SHD -> 3.852.379 04 27 01 02 78 33/98 - - 335319 SHD E46/R40
# USER INFO FIELDS
Unit Date VIN Odometer Assembly Software Service Dealer Tester Program ver.
DME -> 17.02.12 WBAAL32040FH55319 153000 km 7.510.889 7.510.890 1.430.122 011111 12345 -
EGS -> 28.08.98 WBAAL32040FH55319 153000 km 1.423.694 1.423.695 1.000.000 000017 00000 -
# ERRORS IN UNITS
Unit BMWTNR HW SW-FSW ERRORS / SHADOW-MEMORY
DME -> 1.430.940 61 F0 3 errors / 15 errors
EGS -> 1.423.279 23 57 4 errors
EWS -> 8.382.452 02 05 1 error
ABS -> 1.164.896 04 20 3 errors
A/C -> 8.382.446 10 04 no errors
SRS -> 8.372.521 02 30 1 error
IKE -> 8.380.146 04 07 5 errors
LCM -> 8.383.225 06 11 6 errors / 6 errors
ZKE -> 4.533.551 10 11 2 errors / 1 error
RAD -> 8.368.254 43 44 no errors
SHD -> 3.852.379 04 27 no errors
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
DME -> 70/44 - Activation, DISA valve
77/42 - Signal, throttle potentiometer
8F/51 - Control units, self-test
Shadow-memory:
6E/00 - Activation, A/C compressor
71/00 - Activation, tank-venting valve
72/00 - Activation, suction-jet-pump valve
73/00 - Activation, map cooling
7D/00 - Signal, oxygen sensor before cat.conv.
7E/00 - Signal, CAN ASC
82/00 - Signal, CAN IKE
83/00 - Signal, road speed
89/00 - Signal, knock sensor 1
8A/00 - Signal, knock sensor 2
8D/00 - Oxygen-sensor control, control limit
8E/00 - Knock control, self-test
EGS -> 99/21 - CAN DME-Load signal
A0/21 - CAN Timeout ASC
9A/F1 - CAN Gas pedal position
9B/01 - CAN Engine temperature
EWS -> 0F/37 - Power on reset
ABS -> 92/00 - CAN bus error
94/E6 - CAN DME/DDE, engine torque not adjustable
93/FF - CAN DME/DDE message not plausible
SRS -> 03/A0 - Power supply
IKE -> CE/C1 - Outside-temperature sensor
BF/C8 - Internal fault, EEPROM checksum, coding incorrect/incomplete
11/C4 - Thermal oil-level sensor
F5/84 - No CAN message (ASC1)
83/81 - Speedometer signal
LCM -> 16/01 - Turn lights switch / wire, short circuit to ground
17/01 - High beam / headlight flasher switch, short circuit to ground
1F/01 - Activation, motor for HVAC 1
20/01 - Activation, motor for HVAC 2
22/01 - HVAC, front load sensor, short circuit to ground
24/01 - HVAC, rear load sensor, short circuit to ground
Shadow-memory:
33/24 - Sidelight, front right
38/23 - Sidelight, front left
39/03 - High beam, left
3A/04 - High beam, right
41/05 - Low beam, right
42/1F - Low beam, left
ZKE -> 3B/3F - Interior light: Short circuit
38/01 - Wiper: Pump for Window washing or Container is empty
Shadow-memory:
90/24 - Battery Voltage: Open circuit
# SCAN END
# SCAN START
# USER INFO FIELDS
# ERRORS IN UNITS
DME -> 1.430.940 61 F0 1 error / 15 errors
EGS -> 1.423.279 23 57 1 error
EWS -> 8.382.452 02 05 no errors
ABS -> 1.164.896 04 20 1 error
SRS -> 8.372.521 02 30 no errors
IKE -> 8.380.146 04 07 1 error
LCM -> 8.383.225 06 11 no errors / 2 errors
ZKE -> 4.533.551 10 11 no errors / no errors
DME -> 77/42 - Signal, throttle potentiometer
Shadow-memory:
70/00 - Activation, DISA valve
8F/00 - Control units, self-test
EGS -> 9A/E1 - CAN Gas pedal position
ABS -> 93/FF - CAN DME/DDE message not plausible
IKE -> CE/41 - Outside-temperature sensor
LCM -> Shadow-memory:
33/21 - Sidelight, front right
38/21 - Sidelight, front left
# SCAN END
Drizzles is offline   Reply With Quote
Old 01-19-2013, 06:19 AM   #2
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
I think some of your error codes were trigger while u did ur engine swap such a unplugging x and y sensors. Therefore, I recommend that u reset the codes and only play attention to those codes that come back.
I hope this helps. Good luck
sent from my HTC EVO+ using Bimmer App
Old 01-19-2013, 05:41 PM   #3
Drizzles
Yeah, I've done that already, and you were right, some of them did clear and that's basically what was left.
The A/C Compressor I was already aware of and have a new one sitting in my Garage. The Throttle potentiometer I have swapped between the two engines to no avail (same part).
And yeah, I just realised what I posted has both scans in the jumble of text ...
I'll highlight the latest one in RED.
Old 01-20-2013, 07:04 AM   #4
Drizzles
No ideas?
Old 01-20-2013, 10:10 AM   #5
flashmeow
Banned User
I don't know. If those codes are still present then your car would not start or have a difficult time starting but you said she is running just fine (minus tranny feeling sluggish).
Don't worry about the shadow codes. shadow codes are nothing more than codes that were at one time present but are not currently present.
as for all of your other codes...it just doesn't make sense. double check your main engine wiring. see if the DME contacts are corroded. look at the plug/connectors and see if they are damaged or soaked in oil.
I say clear your codes again (to include shadow codes)
