Repaired disa still rough cold idle - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-04-2017, 11:41 PM   #1
Broo102
02 325i sedan
I know this has been discussed, but i was unable to find any discussion re: a DISA rebuild with the idle getting rougher. Any thoughts? I disconnected the Intake VANOS plug, no difference on cold idle.
The DISA rebuild went well--but when I open the flap on it, and hold my finger on the vacuum port it holds ok but doesnt stay all the way. DISA still good?
Appreciate anyone that went through this stage
Broo
Broo102 is offline   Reply With Quote
Old 07-05-2017, 06:37 AM   #2
markusmarkus
My Ride: 2001 330Ci
There are a myriad of issues that can cause your symptoms. The first step is to scan the engine computer (DME in BMWeze) and the automatic tranny computer (EGS) for codes. Btw, if your car has a manual tranny it doesn't have an EGS. Then post the codes.
I'm betting that there are vacuum leaks in the intake system. Yes, you wrote that everything looks fine, but these cars, due to emissions requirements, are very finicky about vacuum leaks. The only way to find all the vacuum leaks is to smoke test the intake system.
Old 07-05-2017, 01:27 PM   #3
Broo102
Thanks Markus
I should have explained more symptoms.
The codes I got in the past are 300 313 1353 1351 maybe a few more, I cant recall. The car shakes, weak power, and rough idle at cold start, but when I turn it off after 20 to 30 sec. or so, it is fine, runs smooth. I would think a vacuum leak would show up all the time? After it smooths out, the idle does not fluctuate like a vacuum leak. I checked the MAF boot and hoses for cracks, nothing.
Any other ideas would be welcome!
