Thread Tools Search this Thread Rating: Thread Rating: 25 votes, 4.84 average. Display Modes
Old 01-26-2013, 06:58 PM   #41
TerraPhantm
My Ride: M3 & ZHP
Unless you're driving a 325, the N52 still had a DISA. 2 of them in fact.
Old 01-28-2013, 07:05 AM   #42
wolfe
My Ride: 330i
128i. DISA wiring harness is present and clipped to the side of the manifold, but no valves.
wolfe is offline   Reply With Quote
Old 02-20-2013, 08:06 PM   #43
pawelgawel
My Ride: 330CI
just found this thread.. I have a 2004 330CI with same shutter... replaced ccv, all boots and hoses, did the vanos seals, spark plugs.. issue persists.
I do have PASoft 1.4, could i use that to update the DME ??
what's the procedure if i can?
Sent from my SGH-I727R using Bimmer App
pawelgawel is offline   Reply With Quote
Old 02-20-2013, 08:28 PM   #44
wildirish317
My Ride: 2004 325Ci vert
PASoft won't do it. Read this thread: http://forum.e46fanatics.com/showthread.php?t=898241
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 02-20-2013, 09:28 PM   #45
pawelgawel
My Ride: 330CI
ok... Luke like a dealer thing to me... hopefully they know what update im asking for.
Old 02-21-2013, 07:22 AM   #46
wildirish317
Ask for the BMW SI B 12 40 06 Engine Electrical Systems upgrade.
Old 02-21-2013, 07:25 AM   #47
pawelgawel
My Ride: 330CI
perfect. thank you!
Old 02-21-2013, 08:21 AM   #48
willsbma
My Ride: 99 323i
Not trying to open a can of worms, but does everyone who is experiencing this issue have the beisan seals in their vanos? I don't remember if there are any threads about the longevity of their system. Has anyone opened up a vanos after 40-60k to check out how they hold up?
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 02-21-2013, 08:50 AM   #49
willsbma
My Ride: 99 323i
Just reviewing some old threads I made.
http://forum.e46fanatics.com/showthr...637&highlight=
Check out post 7 and the date
Old 02-21-2013, 09:23 AM   #50
pawelgawel
My Ride: 330CI
i had this issue before i did the vanos seals... i noticed it the day i tested the car when purchasing it. only happens when i give it and its hitting the 3K range.. after that its smooth.
Originally i thought it was a vacuum leak or something else simple.. but after everything i did, update seems to be the only reason.
ill book an appointment and see what happens.
Old 02-21-2013, 09:44 AM   #51
willsbma
My Ride: 99 323i
If you head in to the dealer, see if they can tell you the DME version maybe?
Old 02-21-2013, 11:54 AM   #52
TerraPhantm
My Ride: M3 & ZHP
I forgot about the x28s
Nonetheless, the DISA version of that motor makes 30 more hp and 20 lb-ft more torque, and retains a fairly linear curve
Old 02-23-2013, 02:31 PM   #53
willsbma
My Ride: 99 323i
Any new ideas?
Sent from my DROIDX using Bimmer App
Old 02-23-2013, 02:41 PM   #54
PainBreak
My Ride: 2004 325i
Originally Posted by willsbma View Post
Any new ideas?
Did you get your DME flashed yet?
Is your car a Stu Stu Stammering Stan at 2800 RPMS? FLASH THE DME! http://forum.e46fanatics.com/showthread.php?t=966614
Enco B046 Android 4.04 Root/FAQ/Help: http://forum.e46fanatics.com/showthread.php?t=967737
PainBreak is offline   Reply With Quote
Old 02-23-2013, 07:28 PM   #55
wildirish317
I'm convinced that the stutter will be solved by the DME flash.
The problem is, it's low on my list of priorities. Today I replaced the driver side front axel in my daughter's 03 Passat, along with the battery, which couldn't hold a charge with the ignition on during part of the process. Our 05 Kia needs a new ac compressor. The weather is warming up, and soon it will be fishing season again. I still have a few fluid changes to perform, on all of the family cars. The stutter is a nuisance, but in the overall scheme of things, a small matter.
I'll get to it, but it will be a few weeks, or months.
Old 02-23-2013, 07:42 PM   #56
jonesenberg
My Ride: '04 330i ZHP 6spd
Just noticed this stutter for the first time yesterday. '04 330i ZHP. As far as I know, the car has original DISA. Will be taking the car into dealer for other warranty work soon. Will update if addressed/fixed, etc.
jonesenberg is offline   Reply With Quote
Old 02-25-2013, 10:29 AM   #57
pawelgawel
My Ride: 330CI
i made an appointment for next Monday.. the want the car for a full day :what:
Ill get a car in the mean time... probably a Hyundai. yay
Old 02-25-2013, 10:38 AM   #58
TerraPhantm
My Ride: M3 & ZHP
Any reason you guys are unwilling to do the flash yourselves? If setting up the software is the issue, get the kit from bmtechnic -- they made it pretty foolproof. With WinKFP, you can do the update in your garage in less than an hour.
Old 02-25-2013, 10:48 AM   #59
pawelgawel
My Ride: 330CI
i do have a question... after heading some comments, the possible reason for the stutter might be because the sw wasn't able to handle a used up o2 sensors as well as it should. I have new o2 sitting around just in case and im wondering if that would solve the issue as well.
Old 02-25-2013, 10:53 AM   #60
TerraPhantm
My Ride: M3 & ZHP
Perhaps. But the issue will comeback. It's better to get the proper software so that you can get the full life out of your o2s
Edit: I see you're in London -- as far as I know, the software issue only affects Ms45.1 e46s, which are exclusive to the US. So you might actually need O2s or some other item.
