Old 01-20-2013, 05:23 PM   #1
adaseb
My Ride: 2002 BMW 320i
To Change Radiator Or Not When Doing Cooling System Maintaince?
A lot of confusion regarding the radiator when it comes to doing the cooling system.
Some say that radiators are usually built for the life of the car while others say since they aren't too expensive and are made out of brittle plastic they should be replaced along with everything else.
I always done a coolant changed with BMW coolant and distilled water, so I am pretty sure my radiator passages aren't clogged.
Also in Canada a new radiator made by Nissens costs about $200. No idea how much an OEM radiator costs probably $350-400.
I think its better to keep the old OEM radiator than replace it with a non-OEM radiator.
adaseb is offline   Reply With Quote
Old 01-20-2013, 05:25 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
OEM radiator is Behr.
What mileage you have? I personally wouldn't change it unless it is damaged by the fan blades or if the bottom is expanded so much it's bent.
Old 01-20-2013, 05:28 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
My radiator failed at 185K miles or so. My Behr replacement has been fine for 60K miles.
See me in NYC in May!
Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m.
dmax on Facebook
Mangofy your E46!
Old 01-20-2013, 05:38 PM   #4
daves325in2012
My Ride: 2004 330cic
In to hear about longevity!
Sent from my DROIDX using Bimmer App
Mysticblau 330cic
Pretty Facelift on..PSS9\\Alpine 9855\\More
daves325in2012 is offline   Reply With Quote
Old 01-20-2013, 06:02 PM   #5
Zchild
My Ride: 2000 BMW 3XXi ZSP
My OEM radiator failed at 210,000 miles...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 01-20-2013, 06:13 PM   #6
Stinger9
My Ride: '04 330Ci
Depends on so many variables, including what you expect from your car in terms of reliability.
New Behr delivered in the USA for under $150US.
Some last long time. Others leak at gasket where plastic joins metal.
Yours probably not clogged depending upon duty cycles.
Do we know your mileage?
Old 01-20-2013, 06:14 PM   #7
E46@46
My Ride: 2003 325xiT
Mine was still working at 155k miles. No leaks but very inefficient and was running hot (not enough to overheat). Changing it made a big difference for me even though it "did not fail". Here is what it looked like. I vote to change it.
E46@46 is offline   Reply With Quote
Old 01-20-2013, 06:15 PM   #8
Mouf
My Ride: 2004 ZHP Sedan
Mine started leaking at the tank seem around 110k. It was just a seap, but I changed it anyway.
Sent from my Galaxy Nexus using Bimmer App
Mouf is offline   Reply With Quote
Old 01-20-2013, 06:18 PM   #9
adaseb
Currently I have 115K miles
Old 01-20-2013, 06:20 PM   #10
Zell
Zell's Avatar
My Ride: so turbo wow
If leaking, yes. If not leaking, no.
When it starts leaking, it'll be a slow leak and won't be catastrophic, so you can wait on it. It's a crap shoot on how long the radiator will last. Some people still have them OEM, others needed a replacement. I had to replace mine at 100k due to a small leak.
Old 01-20-2013, 06:20 PM   #11
adaseb
The cheapest price for the Behr w/ shipping to Canada was around $250
Old 01-20-2013, 06:20 PM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
Eh, I guess if you have the cash go for it.
Here's an example of what you would pay
http://www.ebay.ca/itm/OEM-BEHR-BMW-...#ht_881wt_1271
Old 01-20-2013, 06:23 PM   #13
MercForHire
My Ride: M235i 6MT
change it when it leaks/fails
Old 01-20-2013, 06:28 PM   #14
2003 325i
My Ride: '03 Orient Blue 325i
What Merc said.
Also, what is this cooling system maintenance/overhaul you're talking about? I change my fluid every 50000 kms but haven't found need to change any parts yet...
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 01-20-2013, 06:35 PM   #15
adaseb
Originally Posted by 2003 325i View Post
What Merc said.
Basically everything.
Water pump, Thermostat, Rad hoses, ET, ET Bracket, Auto tranny thermostat, ET Cap, etc.
Don't want the car to break down and have to pay extra to get it towed and pay premium prices at the dealership because I can't wait for parts.
Old 01-20-2013, 06:37 PM   #16
Solidjake
Zero. Leaks.
Solidjake's Avatar
Like I said, you have the cash do it and it will be good for another 100k miles.
Old 01-20-2013, 06:43 PM   #17
Zell
Zell's Avatar
What's the point of changing the ET bracket? Doesn't it just sit on the radiator, and that's it? Or does it actually connect to the radiator for autos? I don't remember seeing a connection on my manual.
Old 01-20-2013, 06:44 PM   #18
2003 325i
Hmmm, how often do you have to do this?
Old 01-20-2013, 06:50 PM   #19
Stinger9
My Ride: '04 330Ci
Can't get somebody here to deliver up to you for cheaper?
www.furiousmethod.com
Old 01-20-2013, 06:53 PM   #20
helalo
My Ride: Z4 , 530i
mine failed at 95k ( leakage) but that was on my Z4, dont E46 and e85 z4 share the same cooling system?
helalo is offline   Reply With Quote
