Old 01-20-2013, 09:59 PM   #1
obd2toolbox
Past Site Sponsor
My Ride: BMW 7
BMW GT1 DIS SSS Diagnostic and Programming Tools
Detalles
BMW group tester one (GT1) is offered to the aftermarket in the same specification that is currently supplied to BMW franchised dealers. It is special-purpose tool of BMW Series.
Gt1 is supplied with a Pentium based laptop PC on a Windows platform connected to a high specification communications and measurement interface.
BMW GT1 DIS V57 SSS V41
DIS Version:V57
SSS version:V41
Description:
1.BMW group tester one (GT1) is offered to the aftermarket in the same specification that is currently supplied to BMW franchised dealers. It is special-purpose tool of BMW Series.
2.Gt1 is supplied with a Pentium based laptop PC on a Windows platform connected to a high specification communications and measurement interface.
3.GT1 can complete coverage of ALL BMW systems, one thing that can only be done using the GT1, this function is called Electronic Control Unit (ECU) programming and configuration. Many of the original electronic systems on modern vehicles can now be re programmed using software; historically any changes to rectify software problems would involve a new ECU which would be purchased from the parts department and that is the only way that the independent market today is able to overcome these problems. The BMW GT1 system allows you program all BMW car ECU's to fix software or to install a blank ECU to a repaired vehicle. GT1 is the only system that allows you to do this and is absolutely essential if working on Freelander, the GT1 is also the only system that provides all diagnostics and programming for the very latest BMW launched this year.
4.GT1 software kit comprises of five system ,TIS system .DIS data system ; diagnosis system .measuring system and management system . You can to test and check data information same time in GT1.
Function:
Read faulty code ,clear faulty code ,data stream .activate state, programming ,component test ,maintenance data information ,components location ,wiring diagram etc...,TIS AND DIS ARE SUPPLY all of system diagram of all of BMW car, Components location, maintenance method and coding information etc. Can completely do all of BMW car system.
Package list:
1. GT1-SCAN Pro main body
2. Network cable
3. GT1 for vehicles with 20pin diagnostic connector
4. GT1 for vehicles with OBII diagnostic connector
FAQ:
Q: Can GT1 do coding and programming?
A: YES.GT1 can do coding and programming. IS is used for diagnose and SSS system is used to do coding and programming. It is good for diagnose cars, which is before 2005 years.
Q: What is the difference between GT1 and OPS?
A: They have one same function is diagnose.GT1 is good for cars before 2005 while OPS is good for cars after that,and OPS can do 2009 year models.OPS can do coding and programming for cars have fiber.
Etiquetas del producto
obd2toolbox is offline   Reply With Quote
Old 11-17-2013, 04:48 AM   #2
nb325i
My Ride: 2001 325i
can the gt1 be used to disable drl's and eliminate false "light out" readings?
A girl who swallows is like owning a BMW, You don't need it, but it's nice to have
nb325i is offline   Reply With Quote
