Old 01-21-2013, 12:12 AM   #1
adrianpl
My Ride: 01 330ci
Misfire codes
My car is putting out these codes:
p0313 - misfire detected with Low Fuel
p0300 - Random/Multiple Cylinder Misfire Detected
p1345 - Misfire cyl 2 with fuel cutoff
p1347 - Misfire Cylinder 3 With Fuel Cut-off
p1343 - Misfire Cylinder1 With FuelCut-off
p0171 - system too lean (bank 1)
p0174 - system to lean (Bank 2)
I am not sure what I should do first.
What i think is maybe wrong?
Change Spark Plugs? (I have put in new NGK about 10K ago)
New Coil Packs?
or my computer is shot
Whenever my car starts misfiring I turn the car off, and then I turn it back on and it runs good.
It starts misfiring when I am idling usually
Where should I start? Would love to here some feedback from the mechanics on the forum.
adrianpl is offline   Reply With Quote
Old 01-21-2013, 11:31 PM   #2
adrianpl
My Ride: 01 330ci
anyone?
Old 01-22-2013, 04:12 PM   #3
J.Schmidt
My Ride: E46 M3
How full is the tank? It looks like you might have a fuel delivery issue...maybe a bad siphon???
J.Schmidt is offline   Reply With Quote
Old 01-22-2013, 10:51 PM   #4
adrianpl
My Ride: 01 330ci
It seams to misfire when their is less fuel, I filled up today so i will see what happens
Old 01-22-2013, 10:56 PM   #5
DyeBmw
My Ride: 330ci 3 Pedals
subed, i have the same issue on mine.
DyeBmw is offline   Reply With Quote
Old 01-25-2013, 01:01 AM   #6
adrianpl
My Ride: 01 330ci
Did u solve it?
Old 01-26-2013, 03:50 PM   #7
bpatel1221
My Ride: 2001 BMW 325i
New Coil Packs?
I am having the same issue, i looked around the forums and found something, but what kind of air filter are you using k&n? that could be the reason that its messing up your MAF, may want to try cleaning the MAF or either your MAF is going bad. Try unplugging the MAF and starting the car see how it runs and drive like a block and check.
bpatel1221 is offline   Reply With Quote
Old 01-27-2013, 01:07 AM   #8
adrianpl
My Ride: 01 330ci
nope, it seams like my disa is bad and my Oil separator needs to be changed along with the hoses. Will see what happens after that
Old 02-08-2013, 07:26 PM   #9
adrianpl
My Ride: 01 330ci
Disa valve was bad. Problem Solved
