Old 01-21-2013, 09:22 AM   #1
hitmanre
My Ride: 2000 BMW 328i
Dent in fender! ):
Anyone have any idea on how to get this out? It's killing me. I swear someone punched my car or something ):
hitmanre is offline   Reply With Quote
Old 01-21-2013, 09:32 AM   #2
McGary911
My Ride: 2004 M3 Convertible
Looks like a pretty big dent, but not scratched. You can try one of those paintless dent removal shops. Some of those guys have a mobile service as well. It looks like it'll be easy to get to. It'll probably cost you a touch over $100 to fix it.
McGary911 is offline   Reply With Quote
Old 01-21-2013, 09:43 AM   #3
hitmanre
is there possibly any DIY for it?
Old 01-21-2013, 09:45 AM   #4
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
No.
I once used one of those Seen On TV kits and it made it worse because it ended up scratching the paint.
Call these guys:
http://www.edmunds.com/car-care/conf...t-remover.html
delmarco is offline   Reply With Quote
Old 01-21-2013, 09:47 AM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
DIY nope
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 01-21-2013, 10:00 AM   #6
McGary911
I guess it's possible to do yourself. The tools are available:
http://www.ebay.com/sch/?_nkw=paintl...d=441612049838
It DOES take quite a bit of experience and skill, which most of us here don't have. My buddy used to take small dents out of my cars, but he knew what he was doing. He used to do this very work at a Ford truck plant in Edison, NJ. The trucks would often get little dents during the build. He was one of the last stops on the line to take 'em out. He made it look kind of easy, but it's not.
Some of these guys make it look easy too:
https://www.youtube.com/results?sear....1.8Pht2-dzbvw
It would be a great skill to have, but certainly not worth the investment in tools, time and junkyard panels to justify fixing only a dent or 2. Shell out the bux to the pros and enjoy your car.
Old 01-21-2013, 10:08 AM   #7
nike001
My Ride: Fergo
I have 3 of those too, but on the rear quarter panel. They're 3 smaller ones though that seem to have been made by the guy doing my suspension trying to get leverage to pull the rear springs out.
Mine are above my gas cap, above the body line that goes to the front side marker light. If you look at my sig, it looks like a ball of light like the sun, but it's actually one of the bigger ones catching light. Would that be hard to fix? Seems like it's in a bad spot.
2015 M235i 6MT
nike001 is offline   Reply With Quote
Old 01-21-2013, 11:17 AM   #8
lcoleman
My Ride: '79 Massey Ferguson
Heat gun + bottle of compressed air turned upside down. The propellant freezes, and the rapid temperature change can pull them out sometimes. Otherwise PDR.
Old 01-21-2013, 12:02 PM   #9
pawelgawel
My Ride: 330CI
^!! what Icoleman said...
Buy 3 cans and a real heat gun, not a hair drier. Try it, I think your dent will come out using that methor... Heat the metal up high and blast it with try ice. The metal will tighten up and should go back into original shape.. if it doesnt work the go to a shop.
pawelgawel is offline   Reply With Quote
Old 01-21-2013, 01:02 PM   #10
BimmersGarage
My Ride: E46 330i
Actually that doesn't look bad.
At least it's not a deep crease.
The best way is to remove the fender and use a autobody hammer and choose one of the dollies to tap out the dent > Gently from the underside. (working "around" the circumference of the dent towards the center. DO NOT strike the dent @ center directly)
BimmersGarage is offline   Reply With Quote
Old 01-21-2013, 01:23 PM   #11
choxor
My Ride: JDM
Sure, you can DIY it IF you know how to do it. If not there's more of a chance of making it even harder or impossible for a professional to remove. Crease that thing and you're going to be in a world of crap.
Old 01-21-2013, 01:45 PM   #12
BimmersGarage
My Ride: E46 330i
Well, the point is... it's a 13 year old fender!
It's already dented.. what (further) harm can OP do by trying to learn to DIY with a few proper hand tool(s)?
And to get OP in the right frame of mind.. Here's a good video on how to use said tools:
Old 01-21-2013, 02:13 PM   #13
choxor
My Ride: JDM
Yeah, that's true if the OP is willing to chance his "13 year old fender". Not knowing what he's doing CAN make it worse. Ask anyone who has watched a PDR tech work, it does take some skill. If he wants to learn PDR and doesn't care whether or not the results are less than perfect then cool, go for it. Maybe he'll get it right. It looks like the body line is part of the dent.
So it depends on what the OP wants.
Old 01-21-2013, 05:11 PM   #14
BimmersGarage
My Ride: E46 330i
That's true..
At least it's not one of those "pinched" decorative lines (or crazy compound curves) you see so often nowadays.. that would be a difficult PDR.
Old 01-21-2013, 05:57 PM   #15
MercForHire
My Ride: M235i 6MT
That dent is unfixable
Time to rat out your car for a new dented, rusty swag style
Old 01-22-2013, 01:01 AM   #16
metal massager
My Ride: frankenbi///Mmer
NOOOOOOOOO!!!!!!!!! DO NOT EVEN THINK ABOUT IT!!!!! I do paintless dent repair, and you WILL crack the paint and maybe even blast it off. A decent shop should he able to do for around $150 and it should be nearly perfect.
Compressed air and a heat gun......hahahhahahhahahahahhahahhhahhahahahhahhahahhahahhah ahh
Last edited by metal massager; 01-22-2013 at 04:43 PM. Reason: more haha for compressed air/heat gun
metal massager is offline   Reply With Quote
Old 01-22-2013, 08:27 AM   #17
RayPooley
My Ride: 320i SE Coupe
Take it to a body shop. The good thing about beemers is that you can remove and refit the fender with a screw driver. They will take it apart, tap the dent out and refit it. It is an skill. DIY and you wil screw it up. Shouldn't cost too much.
Old 01-22-2013, 10:23 AM   #18
hitmanre
Thanks guys I'm gonna do that later today At a friends body shop hopefully I can get the hookup
Old 01-22-2013, 10:57 AM   #19
metal massager
Don't let them paint it for such a little dent...ask them who they use for pdr.
Old 01-22-2013, 12:03 PM   #20
RayPooley
Last time I tried knocking a dent out it didn't go too well. Trouble is knowing when to stop!!!
