E46 Xi Forum
Old 01-21-2013, 11:07 AM   #1
belmarBMW
My Ride: 2002 330xi
Help!!! Need smart mechanics here asap!!
2 problems:
1st this bolt. I finally broke thru and bit snapped. Second bit offset also snapped. I've tried everything. Diamond dremel bit does nothing. THe bolt is a 10.9 grade so its hard. I think I also work hardened it from smacking with a punch so now its UBER hard. Ive heated/cooled and nothing. I dont want to destroy beyond use or order a new knuckle.....HELP!!
2nd the chip in my hub. How would you dress this up? a little sanding to remove any weak chrome?
ID:	486991   Click image for larger version
ID:	486992   Click image for larger version
belmarBMW is offline   Reply With Quote
Old 01-21-2013, 03:14 PM   #2
bikesandcars
My Ride: 2002 325xi-sport pkg
I'm sorry but I can't tell for the life of me what those pictures are for and what the problem is
bikesandcars is offline   Reply With Quote
Old 01-21-2013, 04:52 PM   #3
belmarBMW
My Ride: 2002 330xi
1st 2 are of the pinch bolt on the threaded side of steering knuckle. In pic 1 u can see the bit in the center. pix 3 is to show the chip in outer edge of hub.
Old 01-21-2013, 08:05 PM   #4
mixedgas401
My Ride: 04 325xi
Looks like you are deep enough to start an extractor in there. Try applying a little heat from an oxy acetylene torch. Once its got a slight glow on the knuckle try cranking it out. I would also suggest taking it to a machine shop or auto shop and let them waste drill bits and gas working it out if this don't work or you don't have access to a torch
Sent from my AT100 using Bimmer App
mixedgas401 is offline   Reply With Quote
Old 01-22-2013, 09:45 AM   #5
bikesandcars
So you snapped the strut attachment bolt off in the upright (likely due to corrosion) and would like to extract / drill the remaining bolt out to fix the situation.
An extractor is not generally going to work in this situation. They work for torque-snapped bolts where the remaining "stuck" portion is not corroded or otherwise frozen in the piece. If you still want to go that route you need the biggest extractor you can get and a manual impact hammer might help.
If you have broken drill bits off in the piece you need to get those bits out because you can't drill them. Sometimes they can be pried out or worked a little with a small punch and pulled out with a magnet.
If you need drill bits to go through that tough stuff, I suggest you pony up for a cobalt set, that will generally cut through any standard grade bolt.
Of course you can also heat the upright like mixedgas401 said.
depending on your skill... keep working, take it to a machine shop, or get on ebay for a replacement
Old 01-22-2013, 10:28 AM   #6
mixedgas401
My Ride: 04 325xi
I guess I should have mentioned that the extractor is only going to work with some heat. It was late for me last night.
Sent from my HTC One X using Bimmer App
Old 01-22-2013, 10:29 AM   #7
mixedgas401
My Ride: 04 325xi
BTW I picked up a nice extractor set from Autozone. It is OEM brand but it has actually worked and held up better than my snap on set. And the drills are pretty tough too. I live in north east ohio and yes we use salt and brine so in my line of work a solid set of extractors is a must
Old 01-23-2013, 11:00 AM   #8
kylek325i
My Ride: 2003 325xi sport
soak the bolt in industrial strength penetrant, silikroil/aerokroil would be ideal. PB Blaster might do a little bit. You need to let it sit and soak and keep reapplying penetrant. Try filing the broken end of the bolt and redrilling from that end. Make sure you start with a flat surface though and put the punch back in the toolbox. Clean up the OD of the hub with a file or sandpaper just enough to remove raised metal, dont go crazy. Chase the splines with a triangular file, the fit with the axle is very tight. good luck-
kylek325i is offline   Reply With Quote
Old 01-23-2013, 11:41 AM   #9
Mark M
My Ride: e30 M3 / e90 335d
Go the other way....source a used housing from a boneyard.
Mark M is offline   Reply With Quote
Old 01-23-2013, 05:12 PM   #10
Rickna
My Ride: '01 330xi - '09 IS-F
What side knuckle are you looking for?
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 01-24-2013, 08:21 PM   #11
jcarpfishman
My Ride: '01 330xi
This is *exactly* why I drilled the threads out on the knuckle and replaced the original bolt with a longer one and a lock nut + Loctite on both of mine! I dealt with this on one knuckle and it took me HOURS to drill that S.O.B. out. I wish you luck and patience in your quest to fix this problem, sir... you're going to need it.
A tungsten carbide cutter on the Dremel will work through this stuff, just takes LOTS of time. Unfortunately, the shape of most carbide cutters for the Dremel are not conducive to the tight quarters that you are dealing with here. Ran into this issue with my exhaust studs too when I snapped 2 of those... same fix, got them out and replaced with through bolts and nuts + anti-seize. Any of these little fvckers breaks again on me, the halves of the bolt(s) just slide out the opposite sides and I move on.
The used knuckle may be the best route in this situation though!
jcarpfishman is offline   Reply With Quote
Old 04-27-2013, 01:21 PM   #12
belmarBMW
My Ride: 2002 330xi
heres my subframe insert remove. machining new one to tack in.
also ordered M3 steering rack
Old 04-27-2013, 03:41 PM   #13
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
used knuckle on car-part.com.
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 04-27-2013, 09:31 PM   #14
belmarBMW
My Ride: 2002 330xi
ebayed for 80 bucks
Old 05-05-2013, 06:16 AM   #15
belmarBMW
My Ride: 2002 330xi
subframe repaired
ID:	503928   Click image for larger version
ID:	503929   Click image for larger version
ID:	503930   Click image for larger version
