Old 01-21-2013, 05:04 PM   #1
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
Moisture in LED tails and water in the trunk
I tried searching and only achieved limited results, thus the new thread. I washed my car at one of those brush-less auto washes. I noticed when I got home, there was moisture in the driver side lens. When I open the trunk, I found water on the plastic tray beneath the lens. Just need some feedback as to the best way to fix this. I've read a lot of rec's about using silicone for the lens which I'm okay with. But I'd rather not use silicone to seal the trunk if I don't have to; it'd be like gluing my taillight in place. Would love to see a taillight assembly diagram before taking it all out so I know what to expect. Anyone who can point me in the right direction would be appreciated.
HacksawMark is offline   Reply With Quote
Old 01-21-2013, 07:03 PM   #2
HacksawMark
Found the diagram I was looking for. Gives me a better idea of what to expect and where to order parts if necessary.
Old 01-23-2013, 05:55 PM   #3
sillieidiot
My Ride: '06 AW 330ci
you don't need to glue the tail lights to the car. i would take it off, then the part where the tails are joined, fill it with silicone then put the tails back.
Old 01-23-2013, 10:15 PM   #4
HacksawMark
Thanks for the tip. I'll determine if that is what I want to do when I get the taillight off. Any reccos on what silicone to use? I'm assuming clear...
Old 01-23-2013, 10:18 PM   #5
sillieidiot
yea any clear silicone will do. just make sure you let it dry/cure fully
Old 01-23-2013, 10:22 PM   #6
HacksawMark
Great! Thanks!
