Old 01-21-2013, 10:40 PM   #1
can0n4
My Ride: '04 330xi, '04 X3
My journey to solve poor cold shifting problems... FIXED.
SOLVED SEE BOTTOM OF POST 1:
Problem
- Car does not go easily into first, almost like its hitting a wall.
- Other gears are ok, but get better as I get into higher gears.
- Not consistent
The symptoms
- Easily shifts when car is off, falls into gear effortlessly.
- Will not shift immediately into first second or reverse when cold and running.
- After shifting into other gears (4,5) will shift into any gear.
- If clutch is held for 5-6 seconds, can easily shift into any gear. (this is an important one I feel).
- Jerky take-offs, like I don't know how to drive stick. (this never went away, its still annoying, I blame BMW)
Replaced:
- new slave cylinder.
- new master cylinder.
- new stainless clutch line.
- bled, bled, and bled.
- ordered specific bleeder tool, and bled more.
- pressure bled in a continuous loop so as no air was in the entire system.
- Replaced the Transmission fluid with D4, then MTL, then Royal Purple, back to D4 MTL mix.
I am starting this thread to hopefully someday solve the problem, and help those who experience the same problem.
I bought my 2004 330xi in September. Decided to do routine maintenance and replace all fluids. Soon (a few weeks) after changing the transmission fluid to Red Line MTL, my car became almost impossible to shift into first, second, or reverse, when the car was cold. Weather started changing to so I'm not sure if the two have anything to do with one another. When the car is warm it is slightly better, but not perfect.
A lot of people on here, on other forums, all over the internet chalk it up to being cold. They say the live with it, its normal, all cars do this etc... Problem is, my father (lives down the road) has the same car, same year, same model, same transmission. No matter the temperature his car falls into gear almost effortlessly. This is my fourth BMW in my lifetime and I refuse to believe that this is normal behavior, nor will I accept double clutching, revving, or not using those gears until warm.
Called UUC as well as BavAuto. Both representatives state that the issues is most definitely caused by the BMW SAC (self adjusting clutch) and that it needs to be replaced. I am taking this with a grain of salt because both of them were ready to sell me a full kit on the spot. However they very convincingly sounded like they knew what they were talking about.
My next step is to replace the clutch, although I don't quite see how a 15 minute warm up would allow the pressure plate fingers to behave differently. My gut is telling me it is not clutch, but nothing is left. I have replaced everything in the system but the clutch. I'm going to dig in in about one months time and do the clutch if nothing else works.
Anyone with credible advice, experience, please chime in. Things I have ruled out are synchros, linkeage, and fluid. Unless someone could chime in and tell me the recommended brake fluid being used for this application. Currently I'm using Valvoline DOT 3 and 4 fluid.
Fixed. New clutch, flywheel, and pressure plate fixed the issues below. New clutch was UUC non self-adjusting w/ LUK flywheel. @90K miles. Old clutch disc was still in really good shape, as was the flywheel. I'm blaming SAC.
can0n4 is offline   Reply With Quote
Old 01-21-2013, 11:24 PM   #2
tjyak50
My Ride: Frontier, 240z, W126
Can you feel through the syncros to feel just where the clutch engage /disengage point is?
Rebuilt my 5 speed in a 240Z and struggled with MT90, then GMSMFM then I went back to cheap GL4 and had some improvement.
Might be worth a few more fluid experiments. Especially the cheap ones.
Phoenix, Az
ZHP-C, Frontier, 560SEC, 240Z
tjyak50 is offline   Reply With Quote
Old 01-22-2013, 07:15 AM   #3
can0n4
I can't feel the clutch engage, disengage at all through the syncros. Since you've been inside a transmission think about these two for me:
if the clutch pedal is held down 5 seconds the car will shift easily into any gear. During that time, I feel nothing change in the pedal, in the car, in the gearshift, nothing, nor do I hear anything while lying underneath the car.
Also, increasing the RPMs has little if no effect on shifting, leans me away from the tranny... but maybe not.
Old 01-22-2013, 08:11 AM   #4
sgoetz628
My Ride: 2002 330 CiC
Almost the exact same experience at about 45k miles. Dealer replaced the clutch under warranty. Made no sense to me, but completely solved the problem. At almost 100k, the problem has not returned
I love my car as much today as the day I bought it
sgoetz628 is offline   Reply With Quote
Old 01-22-2013, 11:34 AM   #5
afstud
My Ride: 2003 ZHP 6-speed
I have the same problem and im going to be replacing the fluid with OEM fluid when it gets a tad bit warmer outside, i remember a previous thread where they used the red line fluid and then swtiched to royal purple with horrible result on both, then they switched back to OEM fluid and the shifts were perfect there on out.
2003 330i ZHP 6 speed
afstud is offline   Reply With Quote
Old 01-22-2013, 03:59 PM   #6
can0n4
you should do it this weekend.
Old 04-01-2013, 12:43 PM   #7
can0n4
update because fixed.
