Sponsored by The Tire Rack
Old 01-22-2013, 12:14 AM   #1
trentcdrums
My Ride: BMW 323i Sedan
Will these E39 ins fit my E46?
Seen other posts but I feel lie these would fit... I don't understand the term offset with rims etc.. I habe stock 16's. Attachment 487162 http://chambana.craigslist.org/pts/3510924855.html
Old 01-22-2013, 12:53 AM   #2
Kmoy2002
My Ride: 2002tii, 540i, 330i
Not without hub centric rings. E46 and E39 have different hub bores
Kmoy2002 is offline   Reply With Quote
Old 01-22-2013, 12:57 AM   #3
trentcdrums
Might I ask why? And what would happen if I didn't?
Old 01-22-2013, 01:22 AM   #4
UntaM3d
My Ride: 05 ///M Convertible
Correct, the center part of the wheel, the hole in the middle, is larger on the E39. So, without the hub centric rings, they will not fit snug. But this is typically not your biggest problem, the offset is way off, meaning...these wheels could stick out further on your car and you could run into rubbing issues on your fenders.
I made this mistake a couple years ago. My advice, keep looking, you'll find the setup that will work, both mechanically and aesthetically.
UntaM3d is offline   Reply With Quote
Old 01-22-2013, 01:24 AM   #5
afstud
My Ride: 2003 ZHP 6-speed
technically they will fit just fine, but you SHOULD have hubcentric rings, otherwise all the weight of the wheel is spinning on just the 5 lug bolts and not being supported by the hub and that puts alot of stress on the lugs, but on my Lexus GS i drove with Infiniti wheels for a year without any problems and the infiniti wheels had a bigger hub bore, but this was before i knew about that. ha just my 2cents
2003 330i ZHP 6 speed
afstud is offline   Reply With Quote
Old 01-22-2013, 01:33 AM   #6
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
To be honest, I think it those wheels will make your E46 look dated.
HacksawMark is offline   Reply With Quote
Old 01-22-2013, 01:43 AM   #7
afstud
true true, stick with some nice sport wheels like these. http://chicago.craigslist.org/wcl/pts/3561796473.html
Old 01-22-2013, 07:29 AM   #8
trentcdrums
I hope you're joking..
Old 01-22-2013, 09:06 AM   #9
CSP
My Ride: m54
Have you asked him what the offset is yet?
CSP is offline   Reply With Quote
Old 01-22-2013, 09:31 AM   #10
trentcdrums
Didnt ask. What dies offset mean
Old 01-22-2013, 12:52 PM   #11
trentcdrums
The offset is 20
Old 01-22-2013, 12:56 PM   #12
trentcdrums
And if I'm wrong, I believe my offset on my 16s are 40, so do they change whenever the size of the rim increases?
Old 01-22-2013, 01:56 PM   #13
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
I would recommend running hubcentric rings if you plan on getting those.
The wheel width is also relevant to know how the wheels are going to fit. Diameter will not affect the outer position, just the width and the offset.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 01-22-2013, 03:54 PM   #14
trentcdrums
Do you think these will rub? :/
Old 01-22-2013, 04:16 PM   #15
CSP
My Ride: m54
my winters are et20. Depending on your suspension and what size tires you will run it may run a little. I have sport suspension and 225's all around. I rub mildly.
Old 01-22-2013, 06:58 PM   #16
trentcdrums
I sill have stock
Old 01-22-2013, 07:19 PM   #17
VMRWheels
VMRWheels's Avatar
No way of knowing unless you can find out the width and offset.
Old 01-22-2013, 07:32 PM   #18
trentcdrums
Well the seller told me this "46 has 72.5 MM bore
E39 has 74.1 MM bore
search dude !!" And says they won't fit. What I'd this "bore"
Old 01-22-2013, 07:58 PM   #19
trentcdrums
These should finish the issue, correct? http://www.ecstuning.com/BMW-E46-M3-...ngs/ES1928282/
Old 01-22-2013, 09:19 PM   #20
trentcdrums
Someone help? Thanks!
