Old 01-22-2013, 04:09 PM   #21
Guest021715
Account closed.
Block heater. Does the E46 have one?
If so, use it.
Old 01-22-2013, 04:25 PM   #22
HiHoBrian
My Ride: 05 M3
http://forum.e46fanatics.com/showthread.php?t=621330
Done and done.
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
Old 01-22-2013, 04:38 PM   #23
jfoj
My Ride: 330CiC, M5, X5, E93
Suggest you read the first link below in my signature.
I did not hear any mention of the DISA O-ring or DISA being inspected, this is a big cause of cold start misfires after the car has sat for overnight or even longer.
Also you need to make sure your engine is not running chronically cold, this can lead to excessive carbon build up that causes cold start issues as well.
Read this thread - http://forum.e46fanatics.com/showthr...ghlight=report
Also make sure your engine coolant temp before you start the car is at or below ambient temp, if higher, this is an issue that may need to be addressed.
Old 01-22-2013, 05:04 PM   #24
Sweetness
My Ride: '01 325i
Thanks for all the responses guys. Especially to Trizzuth's. Mine's basically the same way. Nowadays when I re-arrange my car I always take it for a spin around the block. A block heater sounds like a lot of work to be only used a couple days a year. Probably expensive too. Should I switch to German Castrol? Maybe use the BG Moa additive. Will that help?
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 01-22-2013, 05:08 PM   #25
Sweetness
My Ride: '01 325i
DISA will be getting done soon. Thermostat is 18 months old~ 10,000 miles.
2001 325i ZCW, ZPP
Old 01-22-2013, 05:19 PM   #26
jfoj
Does not matter how old the thermostat is, you need to check and verify the engine coolant temperature.
The only way you can accurately condemn a weak thermostat is during the colder Winter months.
Old 01-22-2013, 05:23 PM   #27
Sweetness
My Ride: '01 325i
In September it was reading 91 C. I'll try again when it gets above 20 degrees outside. Also, looked at the block heater post. Looks easy and affordable. I might do it.
2001 325i ZCW, ZPP
Old 01-22-2013, 05:46 PM   #28
shovelit
My Ride: 03 325xi and 04 330x
I'm in Pittsburgh too. Pretty cold this morning. Worse tomorrow. I'll have to ask my daughter how it started when she gets home.
shovelit is offline   Reply With Quote
Old 01-22-2013, 05:50 PM   #29
Zell
Zell's Avatar
My Ride: so turbo wow
Hey I mean if you've got a garage and an extra $140 laying around, you've got nothing to lose.
Old 01-22-2013, 05:50 PM   #30
jfoj
Once the ambient temperature gets above about 70F, then a soft failed thermostat cannot really be detected.
Old 01-22-2013, 05:56 PM   #31
HiHoBrian
My Ride: 05 M3
Installing that oem block heater will probably be the easiest DIY you ever do. Unless you concider washing windows a DIY. For extreme cold weather,a block heater is an exellent upgrade. If you can't find one then PM me and ill send you the link.
Old 01-22-2013, 07:14 PM   #32
sgoetz628
My Ride: 2002 330 CiC
Along these same lines (so technically not a hijack?), my car goes into the garage just before the first snow and stays there until the end of March. However, not being able to stand this situation for more than a month or so, I take it out 2-3 times during the winter and drive it up and down my street for 30 minutes, then put it away. So my question is - do you think this is enough time, in first and second gears only, to fully warm the oil up and boil off all O2? I cannot go beyond my little street, as the car is not insured during the winter
I love my car as much today as the day I bought it
sgoetz628 is offline   Reply With Quote
Old 01-22-2013, 07:24 PM   #33
Zell
Zell's Avatar
Is there any way to hide the engine block heater plug? It looks fugly sticking out the front like that.
Old 01-22-2013, 07:31 PM   #34
jfoj
I recall someone actually putting a 12 Volt heater on a 5 series and running it off battery on a timer. I cannot recall if they put an additional battery in the car or all the details, if I can find the info I will post it.
The Ultimate Engine Heater Setup - http://www.m5board.com/vbulletin/e39...-heat-s62.html
Old 01-22-2013, 07:33 PM   #35
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
As long as the crank speed is consistent to normal temp crank speed then you should be fine. Everything is very very cold around 0 degrees for an engine and starting is is a challenge. It's normal to have weird noises at that temperature.
My e30 does not like to start in the cold. It'll start but it sure doesnt like it. Haha. My e46 is much better. It might be a little loud at first in cold temps but all is well. Totally normal.
Old 01-22-2013, 07:49 PM   #36
dknightd
My Ride: 2002 330 cic
Originally Posted by HiHoBrian View Post
Just remember to unplug all this stuff before driving away.
dknightd is offline   Reply With Quote
Old 01-22-2013, 07:58 PM   #37
dknightd
OP the oil you are using is fine. The electronics appear to be slow because that is the nature of the displays BMW uses. Sounds like your car starts fine. Don't worry about it. It takes longer to warm up in cold temperatures. This is normal. Cars don't care about wind chill when parked.
Old 01-22-2013, 08:19 PM   #38
wanganstyle
My Ride: e36 M3 / E30 GTS1
Let it warm up in the driveway before driving until the heater is toasty and then go for a short drive up/down the street.
Low speed driving lets the oil warm up quicker is not much airflow compared to freeway cruising but if you really want to know then install an oil temp gauge
Sent from my GT-N7100 using Bimmer App
Billet Original CNC LSD for 188K
http://www.wanganstyle.com/
S54B32 E36 M3 DTA S100 Sedan Street car full swap:
http://forums.bimmerforums.com/forum....php?t=1437471
E30 M20 2,7L Alpina + Euro E46 320D ZF 6 speed install
http://www.e30tech.com/forum/showthread.php?t=110010
wanganstyle is offline   Reply With Quote
Old 01-22-2013, 08:34 PM   #39
lcoleman
My Ride: '79 Massey Ferguson
Having an oil temp gauge and living in an area with a lot of traffic (albeit a cold one this time of year), it takes a LONG time for oil to heat up under most circumstances, regardless of ambient temp. I seriously doubt driving up and down the street warms it up fully.
Old 01-22-2013, 09:39 PM   #40
jfoj
Oil takes 1 1/2 - 3 times longer than the coolant to warm up.
Cars with water based oil coolers actually have oil warmers during start up!
Be kind to your engine, drive it easy for at least 20 minutes until you think about getting to heavy with the right foot.
