Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > California
California
Northern California Southern California
Old 01-22-2013, 11:57 AM   #1
Alfredoporro
My Ride: 00 Nissan Pathfinder
FS: Used Z4 short shifter and 5-speed new shifting parts
Hello Guys,
I'm selling a Z4 3.0 short shifter part number 25*11*7*543*193 that I used for 2 months in my car a 330ci 5 speed. I wore down the plastic sides of the bottom part (circle on red) because I used the shifter with a DSSR 237 and without doing this they wouldn't work together. I'm including the yellow plastics washers.
Also, I have these new shifting parts known for wearing out and should be replaced (you can check realoem.com to see the diagram):
Bearing Shifting Arm Bushing part # 25111222015
Gearshift Rod Joint part # 25111222688
Bearing Bolt part # 25111221849
Bush Bearing Oval part # 25117507695
***If you have a coupe E46, you just install and you are good to go. If you have a sedan, you need to bend the shifter. Refer to this thread: http://forum.e46fanatics.com/showthread.php?t=778387***
Prices:
For the Z4 short shifter: $50
For all the other new shifter components: Add $ 25
00 Nissan Pathfinder automatic - Current
00 BMW 323ci automatic - Girlfriend's
03 BMW Z4 3.0 6 speed manual - sold
01 BMW 330ci 5 speed manual - Sold
97 BMW Z3 5 speed manual - Sold
02 BMW 325i automatic - Sold
Alfredoporro is offline   Reply With Quote
