Sponsored by The Tire Rack
Old 01-22-2013, 02:53 PM   #1
lamsv
My Ride: 2001 325iT
Wheel Bolt Length: 10mm Spacer
I purchased a set of 10mm spacers for the rear of my car. From my research, the OEM wheel bolt has a shank length of 26mm. With 10mm spacers, I would need 10mm longer wheel bolts, so wheel bolts with a shank of 36mm. Finding extended wheel bolts with 36mm shank hasn't been a problem. It is finding "locking" extended wheel bolts. The best I can find have a shank of 42mm.
My question: Will a wheel bolt with a shank of 42mm be too long for a 10mm spacer? Will I run into a clearence issue with a wheel bolt 6mm (1/4") longer than what is needed on the back side of the hub?
Thanks!
lamsv: 2001 HELLROT on BLACK 325iT
lamsv is offline   Reply With Quote
Old 01-23-2013, 02:23 PM   #2
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
http://www.radusadirect.com/product/...Cone-Seat.html
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 01-23-2013, 03:34 PM   #3
lamsv
My Ride: 2001 325iT
How they hell did I miss those?! I was on their website yesterday.
HA! I suck at life...
Thanks for the heads up. Problem? Solved!
Old 01-23-2013, 03:37 PM   #4
VMRWheels
VMRWheels's Avatar
It's weird because on the website, all of the locking bolts are arranged by shank length with the exception of that one.
It is literally the last option on the page haha. I almost looked over it too because they get longer and longer and then after 60mm bolts, they jump back down to 36mm.
Old 01-23-2013, 03:38 PM   #5
ECSTuning
ECSTuning's Avatar
My Ride: BMW
With a 10mm spacer we typically suggest a 40mm lug bolt. Typically you can go over a few mm and still be safe. Most of my guys who want lug locks with extended wheel bolts go with something like the Eurasia lock kit (LINK). They slip over the end of your lug bolt then lock down preventing the use of a lug wrench.
