Old 01-22-2013, 03:31 PM   #1
brodaiga
My Ride: 330ci
problem with pasoft scanner
I have wasted 2 hours trying to make this work. All drivers were installed fine. No matter what I do it says "hardware not ready error." Also, it shows the unit as connected when i plug into the computer (green light). When I then plug into the car, light instantly turns yellow and shows as unit is not connected with "hardware not ready" error. Software was installed on Windows xp machine. I have a peake code reader as well and it connects fine.
wtf
brodaiga is offline   Reply With Quote
Old 01-22-2013, 06:16 PM   #2
jfoj
My Ride: 330CiC, M5, X5
You MUST plug the OBD connector into the car because the interface components in the adapter are not USB powered, they are powered via the cars 12 Volts from the OBD connector.
When you do that you should see the drivers actually install.
Old 01-22-2013, 06:18 PM   #3
brodaiga
My Ride: 330ci
I am plugging it into the car!!!!!!!!!!! wasted two hours of my life tried a different laptop as well, POS is being disputed on my card
Old 01-22-2013, 06:23 PM   #4
jfoj
Try the other USB "B" port on the adapter, only 1 of the ports will work correctly.
Old 01-22-2013, 06:25 PM   #5
brodaiga
My Ride: 330ci
not sure what you mean i have the adapter that plugs under the driver foot panel, only one possible port with the other going into the car.
compter------usb cable---------------adapter-------------------car
Old 01-22-2013, 06:41 PM   #6
jfoj
See picture, my BMW Scanner interface has 2 USB "B" ports and only 1 of the 2 ports works properly.
Not sure if they are all this way??
Also try a different USB cable as well.
Name:	BMW Scanner 1.4.0 Interface.jpg
Old 01-22-2013, 06:53 PM   #7
Guest021715
Account closed.
Was the key turned to position 2?
Old 01-22-2013, 06:53 PM   #8
brodaiga
My Ride: 330ci
that is very strange, mine only has one. I bought it from xbox360, a sponsor here, version 1.40. It's not the USB cable since the notebook can see the unit fine under device manager.
Old 01-22-2013, 06:55 PM   #9
brodaiga
My Ride: 330ci
yes, it was. I even tried starting the car as well. I have a peake tool and it works fine. are lights supposed to light up on it when it has power? when I have mine plugged in I have never seen a light on.
Old 01-22-2013, 06:58 PM   #10
jfoj
Try another USB cable just for fun, no loss if you still have the same issue.
Old 01-22-2013, 07:01 PM   #11
Willie00328I
My Ride: 2000 328I sedan
Maybe uninstall the software from your computer then plug in the 1.4.0 to the car and to your computer then load the software while its plugged in, and with the key on.
Willie
Willie00328I is offline   Reply With Quote
Old 01-22-2013, 07:03 PM   #12
brodaiga
My Ride: 330ci
Willie
thanks for the advice, but I played these games for two hours, uninstalling software, drivers. Also, it shows the unit as connected when i plug into the computer (green light). When I then plug into the car, light instantly turns yellow and shows as unit is not connected with "hardware not ready" error. If it is plugged into the computer while it is already plugged into teh car, the light just stays yellow.
Old 01-22-2013, 07:10 PM   #13
Foxtrot_Uniform
My Ride: 325Xi
You supposedly MUST make sure that your laptop does NOT have Internet access while you are installing the software... At least that is what mine said. I have installed it straight away on both XP laptops and Windows 7 laptops... Both run great.
Something to try.
Foxtrot_Uniform is offline   Reply With Quote
Old 01-22-2013, 07:12 PM   #14
brodaiga
My Ride: 330ci
Something to try.
I read that in the instructions. The reason for it per instructions is that older windows xp machines will need internet off to disable automatic windows driver installation. per instructions, I have windows xp 3 and this does not affect me. It is only for turning windows update/driver search off allowing manual installing from the cd which I did.
Old 01-22-2013, 09:33 PM   #15
trj
My Ride: 325Ci
Try a different USB cable and a different USB port on your laptop just for fun.
Also try installing the drivers when you connect the cable to the car not prior to it.
Old 01-26-2013, 01:15 AM   #16
Sport4r
My Ride: E46 325ci, E53 X5
im getting the same error when i plug the scanner on my 2003 325i's OBD2 port but it works fine when i plugged it on my friends 2000 328i using the BMW 20 pin to ODB2 adapter. My 2003 325i does not have the round 20 pin under the hood but my friends 2000 328i has it.
Sport4r is offline   Reply With Quote
Old 01-26-2013, 12:32 PM   #17
Steve855
My Ride: 325xiT
Xcar360 owes me money. Mine didn't work, sent it back to china. Got it back a month later, still same problem as you. Bought another identical scanner off amazon, it worked first try. good luck getting any help from xcar.
DIY or walking since 1986
Steve855 is offline   Reply With Quote
Old 01-26-2013, 12:35 PM   #18
brodaiga
My Ride: 330ci
I'm going to dispute it with my credit card
Old 01-26-2013, 12:36 PM   #19
WDE46
My Ride: '13 128i, '04 330Ci
Mine worked perfectly with Windows 7 Pro 64-bit. I had to search for alternate drivers
I installed my drivers with the adapter plugged into my laptop while on my couch. No car involved.
Old 02-01-2013, 11:39 PM   #20
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Anyone find a solution to this. I have PA scanner 1.4 working on 2000 323i working through 20 pin connector in engine compartment. It is not working on the 2003 325i through the OBD II. It is not recognizing the car.
Update: I have tried it again. This time I hooked it to the car first, turned the key on then booted the computer and it worked. Dont know what may have changed.
BMWCaptain is offline   Reply With Quote
