Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#41 |
boost junky
How could an empty tank not be an issue? For those of you with fi cars you should never romp on them with low fuel. I recommend at least 1/4 tank.
02 E46 M3 - Maximum PSI turbo kit - 10.81@131.39
97 turbo M3 - 9.54@158.24, first in the 9's Maximum PSI - Home of the quickest BMW's in the US Click for used E46M3 turbo parts FS Email us at sales@maximumpsi.com! Like us on facebook to follow our latest builds and upcoming events! - facebook.com/maximumpsi |
#42 | |
My Ride: ZHP Custom Stage 3.5
I was just under the assumption it was missing during idle. (First Start Up) If that was the case. It will be highly unlikely for it to missed fire. It would be another issue.I would agree not to be below 1/4 of a tank when FI.
..::|TrippinBimmer's Boost Build with Cool Parts|::.. 4**whp/3**tq SAE Corrected |
#43 | |
boost junky
![]() If it is missing at idle you need to check the basics: air, fuel, spark. Swap around coils, compression test, swap around injectors.
#44 | |
X2 can go either way it's all good!!!
#45 |
My Ride: TT Turbo 2003 330i
Problem fixed. I had to remove the intake because I had a coolant leak and when I put it all back the problem was fixed.
Now I just need to weld up the exhaust. Aslo dose anyone know of a different or better radiator fan? Sent from my SCH-I605 using Bimmer App
![]() Technique Tuning Turbo Stage 2|Magnaflow Catback|Tein Super Street|EAS Eagle Eyes Tail Lights|3500k Fogs|ATR CF Power Buldge Hood|BMW Performance CF Strut Bar|Dynavin V5|Infinity Reference all around 2011 BMW S1000rr Last edited by zx5rider; 02-10-2013 at 04:04 PM. |
#46 |
Electric or Mechanical
#47 |
Electric
![]() Technique Tuning Turbo Stage 2|Magnaflow Catback|Tein Super Street|EAS Eagle Eyes Tail Lights|3500k Fogs|ATR CF Power Buldge Hood|BMW Performance CF Strut Bar|Dynavin V5|Infinity Reference all around 2011 BMW S1000rr |
#48 |
boost junky
I'd highly recommend a smoke/pressure test to ensure a leak-free system. We put these cars together every day and we still pressure test them.
#49 |
58mm of Bliss
#50 |
I hit a deer a few years ago and the shroud was cracked so I threw it away when I pulled the engine with plans to replace with OEM. Just figured I'd ask before I bought an OEM one.
So I took it around the block and noticed that under boost A/F raito is good but at partial load it goes super lean. Idle is also steady(14-15.4). My partial load I mean just normal driving not flooring it.
#51 |
How lean?
#52 |
Well I have the digital AEM guage and it goes off the scale
#53 |
#54 |
What temperature does the radiator fan come on?
#55 | |
58mm of Bliss
There are 2 water temp sensors on the M54: Cylinder head, and coolant outlet at the radiator. The one on the cylinder head is used to run the EMS adaptations, and also the thermostat switching. The one at the radiator runs the fan.....I've only ever seen temps from the cylinder head sensor....and I'm not sure if most monitoring software even looks at the radiator temp sensor. Edit: Here's what I was able to monitor in 2009...looks like I was watching both. Note the temp range available as well: ![]() One good piece of info is that the radiator fan is controlled by a solid state relay that is mounted onto the fan assembly. (Thats the black blow a the top) This means you can use a low level switching signal to control the fan if you want externally. Last edited by PEI330Ci; 02-12-2013 at 04:56 AM. Reason: Auto-save 1360666579 |
#56 |
Oh okay cool. Also how easy is it to kill a PS pump from running empty?
#57 | |
58mm of Bliss
I never killed my pump, but you will if you run it for a while like this. It would be pretty obvious though, as the steering at slow speeds would be a handful. (Manual steering) |
#58 |
Well its done with the exception of the Power steering. Right now I am using the M3 Pressure plate with the stock clutch and it seems to be holding fine(car hasn't seen full boot though). I have a new clutchnet Kevlar clutch but I won't put it in unless I need to.
![]() Technique Tuning Turbo Stage 2|Magnaflow Catback|Tein Super Street|EAS Eagle Eyes Tail Lights|3500k Fogs|ATR CF Power Buldge Hood|BMW Performance CF Strut Bar|Dynavin V5|Infinity Reference all around 2011 BMW S1000rr Last edited by zx5rider; 02-16-2013 at 10:57 AM. |
