Old 01-25-2013, 01:08 PM   #1
leeezyx3
My Ride: 2001 325i
Bang to start...no really though
so I've had this problem since I got the car, but it doesn't occur too often.
When I turn the key to start the car, sometimes the car just won't start.
I've found that only after banging on the dash right above the cluster, then turning the key, it starts.
I've tested this numerous times: turning the key multiple (7-8) times with no start, then hitting the dash with a start. or turning it only a couple times with no start, then hitting the dash and it starts.
I'm posting this now though because it seems as though this barbaric method may not cut it any longer (it took me about 20 minutes for me to get my car to start last night and this morning).
I was just wondering if you guys had any idea what may be the problem? Perhaps a weak signal from the ignition to the starter?
Also, it really only occurs after semi-long periods of time (overnight) of not starting the car. However, if I start my car, shut it off and wait perhaps a few minutes, it will start up right away.
Also, it seems that may key has gotten slightly harder to put in and pull out the key from the ignition. Any info would be great!
Photobucket
leeezyx3 is offline   Reply With Quote
Old 01-25-2013, 01:13 PM   #2
WDE46
My Ride: '13 128i, '04 330Ci
Wouldn't that point to the actual key switch being bad, or that there is a loose connection somewhere?
Old 01-25-2013, 02:17 PM   #3
lcoleman
My Ride: '79 Massey Ferguson
That does point to an ignition switch. You can test for a 12V signal to the small wire on the starter when trying to crank...if there isn't one and it doesn't attempt to crank, you've pretty well got your answer.
