Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 |
Got cracked diff bushing...what else to do while there?
Discovered that I have cracked differential bushing. Wondering what else to change while I have it apart.
#2 |
My Ride: 03 325iT Sport Wagon
The rear lower control ARM brushing.
#3 |
Flex disc?
#4 |
#5 |
By the way, I have 155000 miles on this...to provide context
#6 |
100% star stuff
Csb.
![]() Bilstein/Eibach B12 Pro-Plus Suspension System | DICE Mediabridge | Valentine One |
#7 |
Drop in a LSD
Seriously though, changing rear end bushings will pay off... check other stuff like sway links. If you can manage to do RTABs it would serve you well. Good luck Sent from my V9 using Bimmer App
![]() I can help with * Reading Codes / Coding your car * R&R FCAs, Tie Rods, Sway links.... * RTABs Need an RTAB tool? Or clutch fan and water pump tools? PM me. Last edited by Ballistic325; 01-23-2013 at 05:23 AM. |
#8 |
I'll probably focus on bushings this round and leave csb and flex disc for another time.
#9 |
History of diff seals?
Lots fail at much lower mileage. Cheap when you have the axles removed. |
#10 |
#11 |
#12 |
#13 |
^no salting in winter time.
My guess |
#14 |
My car gets driven only in summer.
Has never seen a salted road. I'm in LA every summer. |
#15 | |
Lemony Fresh
Diff bushings rear subframe mounts rear trailing arm bushings upper and lower control arm bushings
Mod the driver first. Participate in your local BMWCCA driving school. Have you joined BMWCCA yet?
My Track Schedule The solution to the lack of headroom in the X6 ![]() |
#16 | |
By the way, I was going through the list of all bushings to order and got stumped by a pair on realoem without a part number. I posted a separate tag to see if anyone can help identify it. |
#17 |
Are you sure it is for your car on realoem? If there is no part number, good chance it isn't for your car.
Yes, big nasty job to drop the rear and exhaust. What is an upper control arm? |
#18 |
Thanks stinger. Your post made me go back into realoem...and found the note that explained why the part wasn't listed.
Notes: Items pictured but not listed are not installed on your vehicle. Items pictured without a number are listed on another diagram. |
