E46 325ci xenon problem - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-23-2013, 10:49 AM   #1
ckbeep
My Ride: 04 325ci
I just replaced the d2s bulbs in my car with Philips. When I did the passenger side the low beam assembly inside was sloppy. I took the ignitor off for more room. I can move the low beam part side to side and whatnot. It is very sloppy. Is there a mount it mounts to.
The driver side is not like this. It is sturdy in there.
ckbeep is offline   Reply With Quote
Old 01-23-2013, 04:53 PM   #2
sillieidiot
My Ride: '06 AW 330ci
it mounts to a metal cage that holds the projector. usually that is very firm. the only other thing i can think of is that you broke the arm that allows for up/down adjustment.
Old 01-23-2013, 07:31 PM   #3
ckbeep
My Ride: 04 325ci
I just bought the car and it was already like this I just found out when I went to replace the bulb.
Do I need to pull the headlight off car and take it apart to fix it
Old 01-23-2013, 07:32 PM   #4
sillieidiot
yea pretty much. you'll need to bake the headlight to even see what the problem is.
Old 01-23-2013, 07:35 PM   #5
ckbeep
My Ride: 04 325ci
Bake the headlight?
Old 01-23-2013, 07:45 PM   #6
sillieidiot
to take the headlight lens off. i'm assuming the car in your profile is correct. in which it is a facelift coupe with sealed headlights
Old 01-23-2013, 07:49 PM   #7
ckbeep
My Ride: 04 325ci
Ohh really might just be easier to buy a used headlight
Old 01-23-2013, 08:06 PM   #8
sillieidiot
i guess, but it could just be nothing or small fix. probably save you some money. though if you were intent on buying a used headlight anyways, this would be a good time to learn how to bake your headlights in case you want to install angel eyes later
