Sponsored by BimmerWorld
Old 01-23-2013, 12:17 PM   #1
georgewilliam
My Ride: 2004 325xi
325xi rear coil spring replacement
I have a cracked rear spring. Do I have to be carefull seperating the perch and the body to get the springs out & in? Don't want to damage the rear drive shaft, or differential. thanks, george
georgewilliam is offline   Reply With Quote
Old 01-23-2013, 12:25 PM   #2
lcoleman
My Ride: '79 Massey Ferguson
You have to be careful not to push the suspension down too far, or you can damage the axle. Might be smart to take it loose from the diff first.
Old 01-23-2013, 12:42 PM   #3
Kubica
My Ride: 2003 325xi
Unbolt the bottom of the shock, push down on the rotor, remove spring.
Old 01-23-2013, 01:51 PM   #4
georgewilliam
My Ride: 2004 325xi
ok, thanks. just don't want to damage the drive stuff. george
Old 01-24-2013, 12:21 PM   #5
georgewilliam
My Ride: 2004 325xi
ok, thanks, but will I damage drive shaft when I push down on the rotor?
