Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 1.00 average. Display Modes
Old 01-25-2013, 02:15 PM   #61
WDE46
My Ride: '13 128i, '04 330Ci
323i + S54 = automatic subframe shears.
If you're doing a swap, try to find a 330 engine. Reinforce your subframe. If it has no cracks yet, use the epoxy method. If it has cracks you'll have to repair and weld. After that, just put in the engine and be happy. It'll mate right up to your 5 speed.
An S54 is a bit too ambitious IMO. It also costs more than your car is worth. Hell, a 330 engine is half the price of your car.
Old 01-25-2013, 02:18 PM   #62
erich330ci
My Ride: 2004 330ci
Unbefreakinlievable fatsoup!!! Gotta be one of a kind. Beautiful.
Eric H.
erich330ci is offline   Reply With Quote
Old 01-25-2013, 02:22 PM   #63
JJR4884
My Ride: BMW
you guys realize that link is from a forum member here, right?
JeppeJ.. he has a 100 page build thread, i posted the link in the first page if i'm not mistaken
JJR4884 is offline   Reply With Quote
Old 01-25-2013, 02:43 PM   #64
metal massager
My Ride: frankenbi///Mmer
Originally Posted by fastsoup View Post
It can be done...if you have the coin and lots of time. I won't say that it hasn't crossed my mind. Beautiful end result!
http://www.importatlanta.com/forums/...rt-finish.html
That's JeppeJ's build thread and all his pics!!!!!!! I hope they are not passing it off as something they did!!!???
Last edited by metal massager; 01-25-2013 at 02:47 PM. Reason: credit given to JeppeJ in that link!!!! thats good, he deserves it
metal massager is offline   Reply With Quote
Old 01-25-2013, 02:44 PM   #65
fastsoup
My Ride: 05 M3 Vert/11 X3 M
Dude, relax...I am not saying that's what I did, all I said is that it can be done.
fastsoup is offline   Reply With Quote
Old 01-25-2013, 02:46 PM   #66
fastsoup
Sorry buddy, I looked before I posted the link, I must have missed you on the first page.
Either way, such a sexy beast.
Old 01-25-2013, 02:51 PM   #67
metal massager
Didn't think you were saying that you did it, but looked like the link was trying to say they did it...thankfully after all the pics it states they just condensed a thread here
Old 01-25-2013, 03:05 PM   #68
cak323i
My Ride: ///M3 & 330i ZHP
Originally Posted by Blackbeamer00 View Post
how much would it be all together to get and put in an M3 engine?
my guess is that after paying for an S54 in good condition, you would most likely shell out somewhere around $6k and that's a good bargain S54. Then after paying for additional components (a new transmission compatible to the S54, diff, clutch, wiring harnesses) and labor to get the engine to work in your 323i, I'd guess you will shell out close to $20k or so... but that's just a guess. I know that you will end up shelling a lot of money and my guess is that you still have a lot of research to even contemplate a major project like this.
would i need new transmission?
Your 323i has over 215k on it, what do you think? Adding additional horse power to an already aged transmission and diff will tear them apart that much sooner. You will also need a new clutch as well. you can add a few thousand dollars to the bill on top of that. Also look at replacing your GUIBO and centerline bearing while you're there.... if you don't know what I'm talking about then I suggest you use the search button to find out.
and how much would it be to suprcharge it?
It depends on which engine you plan to supercharge.... a 323i engine would run you $4,845 just for the kit from VF Engineering and this was done from a very simple google search (took me less than a minute to find this answer). If you're going to use a 330 engine then the price goes up obviously, in this case to $8,495 (ESS TS2 Twin Screw supercharger kit).
my engine is at 215k and thats why i would like to replace it.
If you decide to drop an S54 motor then the cost will go up even more....you have to consider most of the systems inside your 323i are obsolete and not compatible with the S54. The ECU, for example will have to be replaced. The engine wiring will all have to be replaced.
In this case, I chose not to include links as you should have no problem doing the research yourself. I would suggest using google to verify the cost of supercharger systems yourself but it is not hard to do. Sourcing an S54 is something you should think about doing carefully since you have obviously shown lack of adequate knowledge to do this type of project. Just because you might be able to source an S54 for under $4k doesn't mean that you got an ///M engine for a steal. That engine will be in serious need of rebuilding and overhauling which will run you over $10k to get it perfect. I have mentioned several things that I seriously hope you will think about.
Yes, I used to have a '99 323i and modded it but when it came to performance I just chose to buy my ///M instead. I saved more money by doing that and got a 330i ZHP for my daily to boot
Whichever way you decide to go I wish you good luck and really hope I don't find a thread by you that you can't make this project work. Take a look at Jeppe's epic build thread for guidance. He doesn't go into too much detail regarding exactly the cost of his project but he did his build just as good as BMW would have done. His E46 ///M3 sedan is, in my opinion, a true BMW E46 ///M sedan. With all that said, yes you can convert your 323i sedan to an ///M3 sedan but it will take plenty of time, patience, research, and money to do this type of project right.
Anyway, good luck!
One final thing to add...if you do this project and complete it, I would love to see and hear about the results of your project
2004 TiAg ///M - 171,000 miles.......................2003 Imola ZHP - 180,254 miles
cak323i is offline   Reply With Quote
Old 01-25-2013, 03:27 PM   #69
erich330ci
My Ride: 2004 330ci
Sorry JeppeJ!!! Was looking at fastsoup's post and thought it was his. Sorry about that. Beautiful conversion. My only question is, exactly where can I find a "donor M3"?
Eric H.
Old 01-25-2013, 03:31 PM   #70
choxor
My Ride: JDM
Classifieds here, ebay, craigslist, auto recyclers. Be resourceful.
Old 01-25-2013, 03:37 PM   #71
Alex323Ci
My Ride: M3 & 323Ci (sold)
Originally Posted by erod225 View Post
I will advise & share my experience to my swap, do what makes you feel happy. Having an E46 m3 sedan is truly far and few, stay away from impressive. Pm me for more info...
Here you go, this guy has an M3 engine swapped in. Ask him about it.
Btw what's the issue with Impressive Auto now? You were all praise before..
Old 01-26-2013, 04:03 PM   #72
theOCHO
My Ride: 330i ZHP 6MT
Originally Posted by cak323i View Post
This and will take time and lots of money!
Wrong.
This M3 conversion is going to end up costing the OP $15 ... and will end up with a misaligned M sticker on the rear deck.
No leather/no cold weather package/no sports package
theOCHO is offline   Reply With Quote
Old 01-26-2013, 04:13 PM   #73
college46
My Ride: Alpine White
this thread should be a redirect for why people should use the search button instead of creating a new thread for every idea that pops into there head.
Going to Bimmerfest West
01 325i ZPP 5 speed, 101,xxx
college46 is offline   Reply With Quote
m3
