E46 Xi Forum
Old 01-23-2013, 08:25 PM   #1
Eurofreak13
My Ride: 325xiT, 318is, 318ic
Weird issue with my shifter...
First off, I've got a 2001 325xi wagon 5 spd;
Leaving work today my shift knob was leaning towards the passenger side while it was in neutral. While driving, as I shifted gears the shifter kept pushing the shift lever to left (passenger side) causing me to grab a much higher gear then desired. For example, while shifting from 2-3 I kept finding 5th.
After about 15min of driving, I was taking off from a stop light & felt whatever was binding "click" back into alignment & everything was back to normal.
My question is, what has or is failing in the shift linkage? A bushing? Any help is greatly appreciated.
Also who makes a good short shifter kit for my car?
Eurofreak13 is offline   Reply With Quote
Old 01-23-2013, 08:59 PM   #2
DyeBmw
My Ride: 330ci 3 Pedals
search up "5th gear detent". Your shift knob is sitting under 5th slightly when in neutral? I had that issue, and it usually corrected itself after the car has warmed up. I fixed it by changing out the 5th gear pin when my clutch was due, and all is back to normal. Hope this helps
DyeBmw is online now   Reply With Quote
Old 01-29-2013, 08:16 PM   #3
Kittepunch
My Ride: 2003 325xi
Apparently that's a pretty common issue for BMW's. I've got it too, but the only way to really fix it is to change out the pin (which in itself is a huge job).
I've heard that doing a transmission fluid flush can solve it for a little bit, or at least make it so it's a little less common.
Kittepunch is offline   Reply With Quote
Old 01-29-2013, 10:25 PM   #4
My325XI
My Ride: 03 325XI Sprt Prem
Same issue with my 5 speed too. I did change my fluid from OE fill to RedLine and I think that the 5th gear flop occurs less often..
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
