eml light dsc light - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 01-23-2013, 10:04 PM   #1
Cayne23
My Ride: 2002 m3 convertible
eml light dsc light
Eml light still coming on. Followed by dsc light then limp mode. After a restart the lights are gone. When i drive, I feel a little surge in acceleration for a millisecond then the eml light comes on. When i slow down, the dsc light comes on. I took my car to my indy shop and I had my codes read. They were codes 76, 77, 77, 79. I took my car back to the shop to get the 2 motor tps sensors replaced, but i asked them to test them first. They did, and told me they are both working correctly. They let the car idle for 15 minutrs, no eml. They test drove the car, no eml. Then they suggested i let them run throttle adaptation software, so i said yes. That didnt help. I still get the eml light. Could my throttle bodies just be dirty and sticking? Today i started my car for the first time and my eml light was on. I did a restart and it stayed on. I drove the car and everything seemed ok. No dsc light, no limp mode, but eml light is on. After 6 restarts the light is still on. Forgot to mention that its only 23 here today which makes me think.the throttle bodies could b sticking. Any ideas? Any help would be great
Cayne23 is offline   Reply With Quote
Old 01-23-2013, 10:36 PM   #2
$ilent ///M
My Ride: 03.5 M3 smg lsb
what do those codes break down to (description)
$ilent ///M is offline   Reply With Quote
Old 01-23-2013, 10:40 PM   #3
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
What makes you think it's one of the TPS's?
Is this what they say your codes are?
76 Ambient Air Pressure Sensor (DME Internal)
77 Intake Air Temperature Sensor
78 Engine Coolant Temperature Sensor
79 Exhaust Gas Temperature Sensor
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 01-23-2013, 11:05 PM   #4
Cayne23
Codes: p0118
p0119
p0120
p0121
Throttle potentiometers signal faorult comparison. I cant remember the exact wording for the codes
Old 01-23-2013, 11:21 PM   #5
$ilent ///M
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Pedal Position Sensor/Switch A Circuit Malfunction
P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
Old 01-24-2013, 02:33 AM   #6
turbo_f22_pilot
The first two would be themostat sensor. Might have to check them, since it's been really cold where you're at the last couple of days.
The last two are for your accelerator pedal. You need someone with a INPA/GT1/DIS laptop or a shop with a GT1 to test your accel pedal and the TPS's for proper functioning.
The laptop would be cheaper since a shop will probably charge around $90+ per hour.
Joy is future proof
CAR:
MODS:
BMWCCA NCC
Old 01-24-2013, 05:30 AM   #7
Cayne23
Ok, sorry, i think i posted the wrong codes. Here's the printout i got.
DME;
*78 ELECTRIC THROTTLE POTENTIOMETER SIGNAL COMPARISON
*76 ELECTRIC THROTTLE SIGNAL POTENTIOMETER
*77 ELECTRIC THROTTLE SIGNAL POTENTIOMETER
*79 ELECTRIC THROTTLE BOTH POTENTIOMETERS
So when i took my car back into the shop, they tested both of them, and said they were working correctly.
Old 01-27-2013, 08:56 PM   #8
Cayne23
Any thoughts as to maybe just dirty throttle bodies?
Old 01-27-2013, 09:44 PM   #9
illestminimike
My Ride: Project Drama
It is probably the one under the intake manifold that is failing.
Old 01-27-2013, 10:42 PM   #10
rcsummers
My Ride: M3
throttle position sensors, and/or throttle body actuator. hopefully its not the latter. that cost $$$$. trust me. I know.
rcsummers is offline   Reply With Quote
Old 04-30-2013, 05:10 PM   #11
tommytoyz
My Ride: 1999 e46 323i
Throttle position sensor on your intake manifold. I think the M3 has two. The car uses the DCS to bring the car into limp mode if it does not know what the gas pedal position is. It can also be your gas pedal, which has a sensor in it too, that connects to the position sensor. It's not the throttle body. The last thing it may be is the wire connectors, corroded or dirty.
tommytoyz is offline   Reply With Quote
