Old 01-24-2013, 11:58 AM   #1
Shlong
My Ride: 2000 325ci se coupe
Kangarooing
Hello all. I own a 2000/01 325 ci se and in the last week or two while driving it jumps only once then its fine but a min or two later it may do it again. Has anyone had this problem before or know what could be wrong cheers. Jamie
Shlong is offline   Reply With Quote
Old 01-24-2013, 12:03 PM   #2
swordsman11868
My Ride: 2003 325i
Auto or manual trans?
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 01-24-2013, 12:06 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Likely a manual trans in first or just getting into 2nd gear??
Old 01-24-2013, 12:08 PM   #4
RayPooley
My Ride: 320i SE Coupe
Bit vague. Does it hop when you have just engaged the clutch and are moving off from a standing position in first gear? Does it do it when accelerating in any gear? Bit more info please.
Old 01-24-2013, 12:31 PM   #5
Shlong
Sorry it's manual
Old 01-24-2013, 12:32 PM   #6
Shlong
Only when driving. Doesn't do it when changing gear.
Old 01-24-2013, 12:43 PM   #7
RayPooley
You sure its a hop and not a stall. Like the ignition suddenly switches off and on again?
Old 01-24-2013, 12:44 PM   #8
mikeetastic
My Ride: lots of 3
@OP are you "new" to your car?.. i think that's normal and happens when your really slow on first gear to second.. it will happen to say your one 3rd gear and go really slow.. i think..
i might try this later but AFAIK it's normal.. i could be wrong tooo hahaha.
mikeetastic is offline   Reply With Quote
Old 01-24-2013, 12:49 PM   #9
Shlong
Its just like that but i could be doing 30-40 mph
Old 01-24-2013, 12:49 PM   #10
Shlong
I thought something todo with the airflow sensor but I'm no mechanic.
Old 01-24-2013, 12:54 PM   #11
mikeetastic
My Ride: lots of 3
if it's 30-40 then it's not.. AFAIK this happens only when your slow or slowing down..
but the kangaroo thing - i always to that to the GF before (now my wife for + years) and plays with it and she hated it every time ..
