Old 01-24-2013, 03:46 PM   #1
steveintheburgh
My Ride: 2004 330Ci
MAF Question
Would a MAF from a manual shift have any issues on an automatic?
steveintheburgh is offline   Reply With Quote
Old 01-24-2013, 04:11 PM   #2
DonaldE
My Ride: 2002 330i
No
They are motor specific, not tranny
DonaldE is offline   Reply With Quote
Old 01-24-2013, 04:46 PM   #3
jfoj
My Ride: '06 330CiC, '03 M5
Just beware they are motor specific and be careful on the difference in years. The 330 also had some changes around 2004 as I recall.
Make sure you also count the wires on each sensor as well.
It is really best to verify part numbers for the application.
Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619
Lower hose fan switch O-ring - BMW #13621743299
