Old 01-24-2013, 05:08 PM   #1
orionstrident
My Ride: 2003 m3 6spd
Ac compressor crapped out time to remove it
So my ac compressor crapped out more so the bearing on the clutch. it still works but the noise drives me nuts so i am gonna save some weight and remove it. THIS IS NOT A DAILY DRIVER i have a 2012 impreza to do that so why not save some weight for track days and Auto-x instead of forking over 350 for a new one. so i am a windows guy anyway in the summer but keeping my heat would be nice in the winter for the windows. Yes i know the compressor de humidifies the air but i have been driving a few days with the belt off and im fine. so my question is what all can i remove and keep my heat ability. I am thinking have the freon professionally taken out then i will pull the condenser, compressor and the hoses? anything else?
2003 m3 6spd - Silver Grey Metallic - Current
2004 325i 5spd - Grey Green Sold
orionstrident is offline   Reply With Quote
Old 01-24-2013, 05:12 PM   #2
Stinger9
My Ride: '04 330Ci
That probably covers it. I'd not sweat the condenser too much as the weight is probably not meaningful. Don't want to leave it there in case you sell the car?
Receiver/Dryer is another possible.
Old 01-24-2013, 05:28 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Just cut the belt...but losing the ability to dehumidify in different weather conditions could get to be an issue, you know. I wouldn't remove it...I'd just leave it off, or cut belt, though I wonder whether that belt 'balances' the forces from the ACC belt at all. IDK for sure.
Of course, unless you live in a state where it's legal (you don't!), you shouldn't vent R134a. It should be recovered by a professional with expensive machine.
Upcoming comedy shows: April 23, Tierney's Tavern, Montclair, NJ, 7:00 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 01-24-2013, 05:45 PM   #4
lcoleman
My Ride: '79 Massey Ferguson
My kind of mod. Be careful, power steering is next.
You can pull the evaporator from under the dash too, but I wouldn't bother. It doesn't weigh enough to be worth all that work. You'll probably have to leave the condenser fan, I think it doubles as the aux fan on e46s.
Old 01-24-2013, 05:48 PM   #5
orionstrident
I dont believe the belt balances because i know of a few guys that are running without the belts. I already said i was going to have the r134a removed professionally Save the Bay haha. but resale isnt a problem that car wont be sold. i was only thinking about removing the condenser to make room for an oil cooler which may come in the near future. AN DMax the only reason i think its okay is ATI's balancers dont have the ability to retain the condenser and i know a few guys running race motors without a compressor so i dont believe the balancing will be an issue.
I guess what i was asking also is what parts are related to the heat?
Old 01-24-2013, 05:51 PM   #6
orionstrident
Condenser fan? i only have a pul on the end of mine. I have a manual and a electronic fan hanging on the back of my radiator. I am not digging for the evaporator just the easy accessible stuff for now. if i ever remove the dash for a cage you bet its gone!
Old 01-24-2013, 05:52 PM   #7
dmax
dmax's Avatar
The heating system is entirely independent. They only meet in the heater core/evaporator box behind console. You really don't want to go in there for a few pounds, do you?
Mangofy your E46!
Old 01-24-2013, 05:59 PM   #8
lcoleman
Most track cars keep heat in case they need to defrost the windshield.
I run a pulley orignally designed for three belts (a/c, ps, and water pump/alternator) with only one belt, and have for a long time. I think you'll be fine.
There should be a condenser fan, according to RealOEM. Guess the aux fan is separate, lucky you. I'd pull that sucker.
Old 01-24-2013, 06:25 PM   #9
orionstrident
yeh i think ill just drop th compressor and all of the lines for now along with my sap and install the headers i have laying around and then have a custom exhaust built with cats further down the line.
Old 01-24-2013, 06:30 PM   #10
lcoleman
Cats....meh.
Old 01-24-2013, 06:48 PM   #11
orionstrident
Cats....meh.
Haha the auto cross class requires them i will be using random tchnology high flow most likely something in the 100 range
